Are We Getting A New Cannondale Supersix?
kafreeman
by kafreeman
The reach will decrease as you increase the spacer height.
Might need to go up a stem size depending on spacer height.
Sent from my SM-G965U using Tapatalk
rmr40
by rmr40
105 SS EVO 3 size 54 strip down and rebuild begins.
Coming from a SS EVO 2 hi mod I was bit shocked at the frame & fork weight!
Complete bike out the box: 8.8kg.
Frame including BB and hanger: 1115g
Fork uncut: 475g
this needs to go on a serious diet...target weight is 6.8kg with etap 11s, sisl2 and farsports 35mm feders.
S6ED
by S6ED
rmr40 wrote:
Sat Sep 12, 2020 8:59 pm
Fork uncut: 475g
The fun begins!
hannawald
by hannawald
BlackForestRider wrote:
Sat Sep 12, 2020 7:19 pm
hannawald wrote:
Sat Sep 12, 2020 6:23 pm
Sat Sep 12, 2020 4:54 pm
Thanks a lot!
I ordered a 58. reach is Almost the Same (5mm Differenz) I can Ride it with the same BB drop like you, But without additional Spacers since my seatpost will be 2cm higher.
hannawald wrote:
Wed Sep 09, 2020 5:55 pm
The one on the right is my 56, on the left is 54 which belongs to my friend.
Be careful with the stem length! You may be confused with reach numbers, reach is measured at stack height. 58 has higher stack height and if you put spacers on 56 to achieve same stack height a measure your reach there, there will be bigger difference than 5mm...reach drops by about 3mm for every 1cm of height..
Thank you, Understood. That means it wil be 5mm + around 6mm (for 2cmStack) = 11mm?
The guy in the shop said, that my arms are longer then average. My armspan is 186cm qt 184cm height. Does that maybe explain to go for the 58?
Hard to say, 58 should fit, probably best to compare with your previous bike. People here and racers usually prefer downsizing, smaller frames are nicer, stiffer, lighter.. 56 would be ok for your 79cm saddle to bb height..(58 as well).
So it depends what stem length and how many spacers you plan..up to 120mm stem and 3cm of spacers (incl headset cover) i would prefer 56..if you need more spacers or longer stem on 56 it's probably better to take 58..
S6ED
by S6ED
Dan Gerous wrote:
Thu Sep 10, 2020 11:48 pm
So my opinion is that thru-axles are indeed better and nicer but just that wouldn't be a deciding factor to change a bike IMO. There are many good reasons to change it though. :mrgreen:
Just weighed my front thru-axle (some Maxle) and rear QR (Mavic) and they weigh in at 99g.
As you may remember, Cannondale had the bizarre idea to design the previous gen Evo Disc with thru-axle front and QR rear...
So 30g heavier than the stock Cannondale thru-axles for the new Evo. So just another reason. :mrgreen:
Nickldn
by Nickldn
Thanks a lot!
I have had similar issues with frame choice being 'between sizes'. I'm the opposite to you with longer legs and shorter arms than average.
I went for the larger frame size, which meant I could have very few spacers and a relatively short stem. A smaller frame size would have allowed me a slightly longer stem, but also needed more spacers. So I chose less spacers and a shorter stem.
If your arms are longer than average then
you can get the larger frame, minimise your need for spacers and still have a long stem. If you go for the smaller frame then unless you are supremely flexible you will need more spacers, but the benefit could be a longer stem.
Choice is yours, but largely comes down to your flexibility.
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Yoeleo H10 bars 7.5kg
Maximilian
by Maximilian
rmr40 wrote:105 SS EVO 3 size 54 strip down and rebuild begins.
Fork uncut: 475g
The "SuperSix Evo" branding is a sticker under the clear coat?! It also looks wonky and not on the centreline of the top tube? Is it camera parallax/distortion or actually wonky?
Sent from my COL-L29 using Tapatalk
Dan Gerous
by Dan Gerous
Maximilian wrote:
Sat Sep 12, 2020 11:59 pm
It was 'over' the clearcoat on mine, which I really appreciated, easily removed. :thumbup: I just wished the UCI didn't force companies to have their big ugly approval sticker under it! :frightened:
Jackofallgrades
by Jackofallgrades
It's over the clearcoat as Dan says, I made the error of trying to peel the 'covering' off mine and made a right mess of it... Better off just removing the whole thing!
Cannondale SSEvo3 'Atticus' - 7.2kg
...Work in Progress viewtopic.php?f=10&t=161634
BlackForestRider
by BlackForestRider
Appreciate your Input! Thanks
Nickldn wrote:
Sat Sep 12, 2020 10:04 pm
Thanks a lot!
req110
by req110
Anyone of you can post name of the biggest tires you were able to mount in supersix?
I am preparing myself for winter, when i would like to ride also some harsher roads with it. So considering some CX tires... Or just use gp5kTL 32mm?
Geraint
by Geraint
req110 wrote:
Mon Sep 14, 2020 8:18 am
Not my bike, but may be of interest:
req110
by req110
Impressive, these are Vision trimax 30, inner 19, outer 24mm.
I am running roval clx50, inner 21, outer 29. So i am expexting those will not fit, but going to 33mm of such type would be still good.
Pistaboy
by Pistaboy
chrispino wrote:
Tue Sep 08, 2020 3:14 pm
Joined the club after pieceing this one together over the last month or so.
Very much loving it so far.
This looks lovely! What is the stem and bar you are using here?
S6ED
by S6ED
Dan Gerous wrote:
Sun Sep 13, 2020 12:02 am
Dan, what is the height of the Evo's top spacer, measured without including the height of the lip at its front side?
I assume it can be installed directly on top of the headset bearing.
Also, does it rotate with the handlebar/fork or is it fixed on the headtube/frame? Sorry for the naive question :roll:
