Are We Getting A New Cannondale Supersix?
Robert
by Robert
Wenne wrote:
Tue Feb 04, 2020 3:15 pm
ready to drive
Nice! I'm thinking of the same setup. I see in the picture that you changed the crank arms to SI and the chainrings to the 8 arm spider. What was the weight saving with that? Do you have any information on the weight of the original stock crankset?
Is that a carbon 0mm offset seatpost?
Wenne
by Wenne
Robert wrote:
Thu Feb 06, 2020 10:36 am
ready to drive
Crank -150 g.
carbon 0mm offset seatpost !
floriansantana
by floriansantana
ready to drive
The weight of the original Si crankset with FSA chainrings is around 785g. I think my Hollowgram Si with 8 arm spider weighs around 600g, so the saving for the Si plus spider has to be somewhere in between.
Cannondale SuperSix Evo Disc
Cannondale SystemSix HiMod Disc
@floriansantana
DDDJDD
by DDDJDD
Picked up my new size 54 SuperSix Ev(enge)o this week. It was pretty much a complete strip of the Ultegra model. The finishing paint is amazing. The bike shop weighed it at 16.1 lbs without pedals or bottle cages. I figure with my Assioma Duos and 85g bottle cages, it's about 17 lbs. I will swap out the cassette that was on it and get the carbon seatpost.
So for what I swapped.
SWorks Aerofly II 42cm bars
Venge stem 120mm
Roval CL50s
SWorks Turbo RapidAir tires (28c)
Ultegra Di2 (shifters and derailleurs)
SM-RT 99 rotors, 160-140
Rotor Aldhu crankset (52x36 165mm)
Bontrager Aeolus Pro saddle
Seems like with a cassette upgrade, traditional stem, narrower tires, and lighter stem, sub 16 lbs would be likely.
Discodan
by Discodan
floriansantana wrote:
Fri Feb 07, 2020 1:12 pm
ready to drive
The stock FSA chainrings weighed 270g, I swapped them out for 8 arm spiderrings at 207g on the stock SI arms so only 63g saved there but 10,000% faster looking
PUNlSHER
by PUNlSHER
Discodan wrote:
Sun Feb 09, 2020 1:14 am
ready to drive
show the pics pls :beerchug:
cerro
by cerro
DDDJDD: Pictures! Very curious of how it looks with the Vengestem on that bike.
/jonas l
Danielhorn1995
by Danielhorn1995
My new SuperSix Evo 2020 Rim Brake build
15.4lbs without the Carbon Seatpost.
Specs:
SuperSix 2020 Rim brake in a 56cm
Easton EC90 Tubulars
Easton EC90 SLX Handlebar 40cm
Zipp SL Speed stem 120mm
Cane Creek EE Direct Mount brakes
Ultegra Di2 group set
Dura Ace Cassette 12-28
SRAM Red 22 Chain
SRAM Red Crankset 172.5
Quarq DZero Powermeter w/ cheap chainrings at the moment.... (I'll take suggestions)
Dura Ace 9100 pedals
Discodan
by Discodan
I won't repost but there's a pic of the finished product in late November in the thread
Sent from my Pixel 3 XL using Tapatalk
PUNlSHER
by PUNlSHER
ready to drive
U mean KP408 & KP305?
Hoven
by Hoven
Danielhorn1995 wrote:
Sun Feb 09, 2020 8:48 pm
Specs:
SRAM Red 22 Chain
Dope! #savetherimbrake
Discodan
by Discodan
PUNlSHER wrote:
Mon Feb 10, 2020 12:52 pm
ready to drive
Yes the chainrings are KP408, I don't think the stock SSe3 arms are KP305 though. Although they are labelled SI I don't believe they are hollowgram, can any experts pitch in?
Discodan
by Discodan
Discodan wrote:
Sat Nov 09, 2019 6:28 am
Finished the build, converting a 105 donor model to Ui2. Hovering at 7.4 ready to ride with 28s. Just need to trim the steerer and bleed the brakes again and its good to go. Very happy with the outcome
Here's the original pic with the crankarm
PUNlSHER
by PUNlSHER
Discodan wrote:
Tue Feb 11, 2020 3:00 am
Stock crankarms is KP423 (I thought you changed them to KP305 but you didn’t), you only changed FSA chainrings to KP408 & save about 60g if I understand you correctly
ch00bzs
by ch00bzs
Specs:
SRAM Red 22 Chain
Damn that's light. i just found out that my Cannondale SI Crank paired with Power2max NG is heavy af.
