Are We Getting A New Cannondale Supersix?
Dan Gerous
by Dan Gerous
Custom painted, built by Stage21, looks pretty nice:
Wenne
by Wenne
:welcome:
S6ED
by S6ED
Dan Gerous wrote:
Tue Oct 15, 2019 3:34 am
Nice but voiding the warranty is a no go for me.
Wenne
by Wenne
FSA -12 :thumbup:
brearley
by brearley
Is there a lighter solution to pf30a bottom bracket than the token ninja setup?
As they all seem to screw together I'm thinking none are going to be sub 100g and I'd consider full ceramic replacements to the bearings to drop weight further
hernejj
by hernejj
brearley wrote:
Tue Oct 15, 2019 10:49 pm
I guess it depends on what cranks you're planning on using. But here are the ones I know about:
https://wheelsmfg.com/bottom-brackets/c ... pf30a.html
https://www.c-bear.com/en/products/pf30a
https://www.bbinfinite.com/products/osb ... 9864585539
N1720
by N1720
@Wenne what's the weight of your bike? Did you use full-length housing for the shift cables or did you use cable stops inside the downtube? Is the shifting quality as good as it is normally?
Dan Gerous
by Dan Gerous
Aren't the stock Cannondale alloy PF30 cups much lighter than all these? I never had any issues with them.
Wenne
by Wenne
N1720 wrote:
Wed Oct 16, 2019 6:02 pm
full-length housing for the shift cables ! 8,1 kg...
Wenne
by Wenne
shifting quality good...
bike size 54 with body size 170 :noidea:
S6ED
by S6ED
Dan Gerous wrote:
Wed Oct 16, 2019 6:06 pm
This must indeed be the lightest option. The stock aluminium cups are very light, my bike (Evo2) came with these plus a plastic FSA sleeve (10g or so) between them that insulates the BB axle from the elements. The plastic sleeve can be removed, if one so wishes, but its good to keep it as it keeps the whole BB assembly clean and dry.
S6ED
by S6ED
alexneumuller
by alexneumuller
Back from the Painter. Frame weight is 830grs after repaint in a size 56
C36 wrote:
alexneumuller wrote:The frame was without fork es 870gr with two small pieces of card board and some clear protector wrapping g. So probably around 850gr.
Will weigh frame and fork when I get it back.
Painted or raw frame before painting it?
I saw it in fatcreation Instagram, really nive
Envoyé de mon iPhone en utilisant Tapatalk[/quote]
IF Crown Jewel TI
IF Crown Jewel Steel
Open New UP
Stinner Ti
Speedvagen
Parlee Z-Zero Disc
Cielo Road Racer
Cervelo P5d
English Cycles 10th Anniv Edition
Cannondale SS Evo Disc
alexneumuller
by alexneumuller
One piece BB would work. The piece inside is the rubber tube
alexneumuller wrote:Will check and take picture when the frame is back with me. Should be Thursday or Friday
TiCass wrote:Can we get more detail from the bottom bracket area, is the opening completely free from obtrusion? Can we put a one-piece bottom bracket in that?
IF Crown Jewel TI
Open New UP
Stinner Ti
Speedvagen
Parlee Z-Zero Disc
Cielo Road Racer
Cervelo P5d
Wenne
by Wenne
Devotional wrote:
Sat Aug 10, 2019 4:13 pm
Still waiting on my ship to get a 51 and a 54 in to try . I’m wondering what a 54 with a saddle height of 69.5cm from bb will look like . I’m 5ft 8 . The shop had a caad13 in 51 in . Guy told me I’d be a 54 but I’m not so sure
Frame 54 , 69,5cm from bb...
