Are We Getting A New Cannondale Supersix?
For those not running the SAVE bar/stem what stem are you using to still get a nice, clean look?
So far I think I'm going Roval Rapide bar and was thinking of getting the Tarmac SL7 stem with that (the integration looks very similar to Evo) but wondered what other options there are out there.
Farsports F1 seems to be the most used one.
I have it on mine, they do a 3D printed spacer to put below the bar/stem to keep everything nice and tidy.
I just ordered a Farsports f1 bar and relevant spacer for my 2021 supersix. I know it has previously been discussed but does anyone have a final answer on how to run a single spacer between the bearing and stem? I would prefer to use the supplied one from farsports but understand that they dont contact the headset correctly to pre-load the bearings.
Hi Guys,
I am building up a supersix 2021 himod Team Replica. I have a question about the cbear PF30A-86-R with the aldhu 30mm 152mm axle. On non drive side I have a big gap between the crank arm and the cbear bottom bracket. I assume that I use the correct cbear and I only have to run a aldhu spacer. Anyone run the same setup and can confirm this. Would be much appriciated.
I‘m not sure man, but your axle seems very long. With a normal pressfit BB with bearings inside the frame, you normally use a 11,5mm spacer on the DS and a 2,5mm spacer on the NDS and the use the preload adjuster for the small gap to get the bearing preload. Your BB shells outside of the frame seems to measure about that, so not sure why there is such a big gap left. Not sure if you get the right position inside the frame, if you just put a spacer on the NDS. You can do it eventually and it will work, but the crankset might be off center.R3nlot wrote: ↑Thu Jun 16, 2022 7:44 amHi Guys,
Cannondale SuperSix Evo Disc
Cannondale SystemSix HiMod Disc
@floriansantana
@floriansantana
Thank you for the feedback and you are right. I just received an email from cbear and they say I should use the standard axle which is 147mm. After installing this I still have around 2/3mm of slack.floriansantana wrote: ↑Thu Jun 16, 2022 9:39 amI‘m not sure man, but your axle seems very long. With a normal pressfit BB with bearings inside the frame, you normally use a 11,5mm spacer on the DS and a 2,5mm spacer on the NDS and the use the preload adjuster for the small gap to get the bearing preload. Your BB shells outside of the frame seems to measure about that, so not sure why there is such a big gap left. Not sure if you get the right position inside the frame, if you just put a spacer on the NDS. You can do it eventually and it will work, but the crankset might be off center.R3nlot wrote: ↑Thu Jun 16, 2022 7:44 amHi Guys,
with the preload adjust I can get it tight!
IMG_6865 by Noel Renlot, on Flickr
How heavy are you Stuey? I'm 82kg and never had it slip once at just over 5NM and it doesnt creak. Perhaps your seattube hole is slightly large in tolerance?
80kg. I've just tried a different brand of Carbon paste (which seemed a bit grittier) and another torque wrench to make sure I'm not under torquing it. Doesn't seem I missing an obvious trick then?
I own a Pro Vibe SL bar and like to combine it with the Tarmac stem on EVO. Problem is the top spacer won't fit.Stueys wrote: ↑Wed May 25, 2022 2:13 pmFor those not running the SAVE bar/stem what stem are you using to still get a nice, clean look?
I don't get why a brand like Vision/FSA doenst create a custom top spacer for specific frames, like Deda does.
I am in the UK and I also had a crash on my SuperSix which has left the fork unrepairable (the frame is ok), I had it assessed by a professional carbon repairer.Bfriesen wrote:Yeah, definitely do this. It won't be quick (I was recently quoted September for a replacement frame) I was told that my bike was safe to ride until then and that the damage was "cosmetic", but then your damage is much worse than mine. I'm not sure if I buy that, or if I'm comfortable riding it, but I guess we'll see. But at least you will have a new frame (hopefully) for free.RDY wrote: ↑Sat Feb 12, 2022 7:31 pmI'd suggest lodging a warranty crash replacement claim directly with Cannondale.adberg87 wrote: ↑Sat Feb 12, 2022 7:28 pmTo clear things up, the crash warranty is from Cannondale, which is a small discount on a replacement frame. I had no luck finding any LBS with any stock, nor any future availability looking any but promising. They did offer a hi-mod at the standard price, just not within my price range.
How do I go about getting a replacement fork/frame from Cannondale directly? My LBS have contacted them and they are just saying ‘we don’t have anything’. Cannondale provide no contact details on their website either which is very frustrating.
It has left me with no bike after an accident which wasn’t my fault!
freespeed wrote: ↑Mon Jul 04, 2022 8:35 amI am in the UK and I also had a crash on my SuperSix which has left the fork unrepairable (the frame is ok), I had it assessed by a professional carbon repairer.Bfriesen wrote:Yeah, definitely do this. It won't be quick (I was recently quoted September for a replacement frame) I was told that my bike was safe to ride until then and that the damage was "cosmetic", but then your damage is much worse than mine. I'm not sure if I buy that, or if I'm comfortable riding it, but I guess we'll see. But at least you will have a new frame (hopefully) for free.RDY wrote: ↑Sat Feb 12, 2022 7:31 pmI'd suggest lodging a warranty crash replacement claim directly with Cannondale.adberg87 wrote: ↑Sat Feb 12, 2022 7:28 pm
Hi, I had my Supersix frame replaced under warranty and I kept the original fork.
I can sell it if you are interested. It has less than 200kms on it and it has been cut, but it still has space to put some spacers under the stem.
