The only other thing I can think of is that it's not torque'd up enough - when I've taken my crank off and put it back on I've had had that kind of play if it's not fully pressed on and torqued but as with the driveside probably unlikely. I think as you say adding an extra shim or 2 will fix it.TDA wrote: ↑Thu Apr 01, 2021 9:30 amThanks for the comment! Yes the drive side has the 2.5mm spacer and then the bearing shield. The wave washer is slightly pressed but I have the feeling that it needs more compression. The only way is adding an extra shim I guess, but there are already 3 shims in between... Thanks again!
Are We Getting A New Cannondale Supersix?
Thanks again, I'll check everythign again later today and see if the 2 shims will fix it. Also re-check the torgue with another torque wrench.dnb72 wrote: ↑Thu Apr 01, 2021 9:42 amThe only other thing I can think of is that it's not torque'd up enough - when I've taken my crank off and put it back on I've had had that kind of play if it's not fully pressed on and torqued but as with the driveside probably unlikely. I think as you say adding an extra shim or 2 will fix it.TDA wrote: ↑Thu Apr 01, 2021 9:30 amThanks for the comment! Yes the drive side has the 2.5mm spacer and then the bearing shield. The wave washer is slightly pressed but I have the feeling that it needs more compression. The only way is adding an extra shim I guess, but there are already 3 shims in between... Thanks again!
Highly unlikely but perhaps check that the spindle is 109mm and the BB shell is 73mm. Possibly some grit in one of the arms stopping in fully engaging with the spindle. Other than that bolts not being torqued enough as previously stated.
Thanks for the comment, it's indeed a 109mm. Good point about the grit, I'll check that as well!ccparkhill wrote: ↑Thu Apr 01, 2021 10:02 amHighly unlikely but perhaps check that the spindle is 109mm and the BB shell is 73mm. Possibly some grit in one of the arms stopping in fully engaging with the spindle. Other than that bolts not being torqued enough as previously stated.
Measure the bunch of shims you have on there plus the one that you are going to add.TDA wrote: ↑Thu Apr 01, 2021 9:29 amThanks for the comment! Yes the drive side has the 2.5mm spacer and then the bearing shield. The wave washer is slightly pressed but I have the feeling that it needs more compression. The only way is adding an extra shim I guess, but there are already 3 shims in between... Thanks again!
Then find the spacer kit and just add the correct mm spacer on the non drive side.
https://www.cannondalespares.com/Cannon ... il/3-42959
"In my experience, there is only one motivation, and that is DESIRE.
No reason or principle contain it or stand against it........"
Thanks for all comments. I added another 0.5mm shim and it's much better. There is still some very small movement when I push the non-drive side crank in horizontal direction. If I add another shim it's gone and there isn't any movement possible. I doubt what to do now, I don't see the added value from the wave washer if I add another shim. The instruction letter says: "Tighten the fixing bolt to 40Nm and check to see if wave washer is properly preloaded (STILL HAS SLIGHT WAVE AND NOT LOOSE)". If I add another shim there isn't any "wave" aymore, so I guess it's normal that this system has a little movement in horizontal direction.
- Dan Gerous
With radial bearings (most BB30 bearings are), you don't want to completely compress the wave washer. These bearings, by design, are not meant to handle too much side load. If the wave washer is fully flattened, it's too much and may reduce the bearing's life. But in my experience, with just a slight compresssion of the wave washer, there shouldn't be side to side movement in the crankset... Was there any play in the bearings themselves?
My cannondale is quite old, so my experience may not be relevant. But my BB30 spindle is interference fit with the bearings - they only go in easily if the spindle is frozen. Once it warms up, it's stuck unless you tap with a mallet. Never had a problem with lateral play in the system.Dan Gerous wrote: ↑Thu Apr 01, 2021 2:49 pmWith radial bearings (most BB30 bearings are), you don't want to completely compress the wave washer. These bearings, by design, are not meant to handle too much side load. If the wave washer is fully flattened, it's too much and may reduce the bearing's life. But in my experience, with just a slight compresssion of the wave washer, there shouldn't be side to side movement in the crankset... Was there any play in the bearings themselves?
My gravel bike has a SRAM BB30, which uses the a nylon collar to adjust the bearing preload. I've stripped one out during a ride, that piece is marginal at best. Prefer Cannondale's system.
- Dan Gerous
Normally, yes, the spindle is tight enough in the bearings that it shouldn't really move and should not be insertable just by hand, they are supposed to be tapped in with a rubber mallet. Not all bearings have equal manufacturing tolerance though.spud wrote: ↑Thu Apr 01, 2021 5:34 pmMy cannondale is quite old, so my experience may not be relevant. But my BB30 spindle is interference fit with the bearings - they only go in easily if the spindle is frozen. Once it warms up, it's stuck unless you tap with a mallet. Never had a problem with lateral play in the system.Dan Gerous wrote: ↑Thu Apr 01, 2021 2:49 pmWith radial bearings (most BB30 bearings are), you don't want to completely compress the wave washer. These bearings, by design, are not meant to handle too much side load. If the wave washer is fully flattened, it's too much and may reduce the bearing's life. But in my experience, with just a slight compresssion of the wave washer, there shouldn't be side to side movement in the crankset... Was there any play in the bearings themselves?
By the way, you can convert your SRAM BB30 to use a wave washer and shims if you prefer. The adjusting collar is removable entirely, so you can just replace it with spacers. That's how you install SRAM BB30 cranksets on Cannondale BB30a and PF30a 73mm BB shells as there is no room for a collar. Or, I think Cane Creek makes a nicer, more durable alloy collar.
If for some reason you need large side preload force. Consider using Angular Contact bearings (WheelsMFG / Enduro make some of these).TDA wrote: ↑Thu Apr 01, 2021 2:40 pmThanks for all comments. I added another 0.5mm shim and it's much better. There is still some very small movement when I push the non-drive side crank in horizontal direction. If I add another shim it's gone and there isn't any movement possible. I doubt what to do now, I don't see the added value from the wave washer if I add another shim. The instruction letter says: "Tighten the fixing bolt to 40Nm and check to see if wave washer is properly preloaded (STILL HAS SLIGHT WAVE AND NOT LOOSE)". If I add another shim there isn't any "wave" aymore, so I guess it's normal that this system has a little movement in horizontal direction.
But normally, you don't. Radial contact bearing is better in normal situation.
Stupid question, but have you tightened the bolts on both side to the correct torque which is around 40Nm? Mine is almost too tight with one additional washer.
Cannondale SuperSix Evo Disc
Cannondale SystemSix HiMod Disc
@floriansantana
@floriansantana
Thanks, there is only side to side movement, no play on the bearings. In fact I'm compressing the wave washer more by pushing, so it seems logic to me thar there is a little movement. Thanks for thinking along!Dan Gerous wrote: ↑Thu Apr 01, 2021 2:49 pmWith radial bearings (most BB30 bearings are), you don't want to completely compress the wave washer. These bearings, by design, are not meant to handle too much side load. If the wave washer is fully flattened, it's too much and may reduce the bearing's life. But in my experience, with just a slight compresssion of the wave washer, there shouldn't be side to side movement in the crankset... Was there any play in the bearings themselves?
Yes, I did. Even a bit more to see if that would solve the (possible) issue. Thanksfloriansantana wrote: ↑Thu Apr 01, 2021 8:35 pmStupid question, but have you tightened the bolts on both side to the correct torque which is around 40Nm? Mine is almost too tight with one additional washer.
[/quote]
That's a very good idea. If the collar strips out again, that's the approach I will take.
[/quote]
