Are We Getting A New Cannondale Supersix?
TobinHatesYou
by TobinHatesYou
Hexsense wrote:
Sun Dec 04, 2022 6:09 am
Still not a SystemSix replacement I assume ?
We were only shown the SuperSix. And no it doesn’t look to me like it will make the SystemSix redundant.
What I saw was a very nice overall package with definite improvements in both aero and compliance in the rear half of the bike.
C36
by C36
I missed the presentation but I just want it to ride better than curent gens.
CaadDaddy
by CaadDaddy
Can someone just be unethical and leak the bike already?
CAAD8FRED
by CAAD8FRED
CaadDaddy wrote:
Thu Dec 08, 2022 7:37 pm
The leaks aren't the same anymore.
nunokas
by nunokas
Heard the handlebar setup was designed by MOMO :twisted:
daninplymouth
by daninplymouth
Bike is here and pleasantly surprised I thought it'd be plain black but has a nice metallic flake effect. Shame it's been so cold here I haven't got to have a test ride yet
Pottermouse
by Pottermouse
Sun Dec 04, 2022 1:06 pm
When does the embargo end?
TLN
by TLN
Sun Dec 04, 2022 3:55 am
nunokas wrote:
Sun Dec 04, 2022 3:26 am
Same geometry, beefier down tube and a new handlebar.
There's obviously more than that.
1 second faster, more aero and compliant?
His: Orbea Orca OMX
TobinHatesYou
by TobinHatesYou
TLN wrote:
Tue Dec 13, 2022 7:42 pm
How do you make rigid bikes more bendy? You can 1) flatten tubes and/or 2) make the tubes bent by default and/or 3) smush triangles.
daninplymouth
by daninplymouth
Does anyone know what hub I need to run Shimano 11s on HollowGram 35 wheels? My new Supersix has SRAM 12sp so I got the dt Swiss hub for my farsport wheels so they now fit on the new bike, however I was planning to put the the Cannondale’s back on my old frame and not sure what I need to swap them from SRAM to Shimano
ry5n
by ry5n
I'm having a new Evo 3 built up in January (despite the Evo 4 coming soonish). Especially with integrated cables/hoses, I like the idea of SLT (solid lubricant) bearings. Does anyone other than CermicSpeed make these yet? Is anything available for an Evo 3 (size 51/54) headset?
TobinHatesYou
by TobinHatesYou
ry5n wrote:
Fri Dec 23, 2022 10:57 pm
The hoses don't go through the bearings on the SSE3 so you really don't need to worry about using SLT stuff. CeramicSpeed only makes them for 1.5" uppers and lowers AFAIK, which means they aren't an option for the SSE3.
Wenne
by Wenne
New Cannondale Supersix Evo 4
Wilfors86
by Wilfors86
LedZeppelin007 wrote:
Fri Jul 09, 2021 6:13 pm
dnb72 wrote:
Fri Jul 09, 2021 7:53 am
Fri Jul 09, 2021 12:20 am
So, I'm a bit frustrated. No matter what I do (within reason), my non-HM SS EVO Force is still a pig. Yes, Force is heavy, I know, but not THAT heavy. I easily got a Canyon ultimate SLX with Force down to 7.4 kg.
With the Quarq PM, an upgraded 140g saddle, no pedals, cages, or mounts, and with Zipp 303FC (the new ones), and 30mm Schwalbe Pro Ones, I'm sitting at bang-on 8kg (size 58). That would be fine if it were an all-out aero bike, but it's supposed to a all-rounder/climbing bike! I could save 100g total by putting the 10-33 cassette back on (10-36 on now) and by moving to 28mm tires. Beyond that, though, it's going to cost a fortune. $300 for a new cockpit, $300 for a new cassette, and $350 for some new crank arms probably gets me half-a-kg. Looking at 7.45kg.
That's very aggravating. Feels like I should've just picked up a TCR or an Emonda. Especially considering the issues I've have with shifting and with my headset.
Having put a significant amount of money in at this point (at least $1500 after selling the factory wheels) to be at 8kg is kind of a joke' especially with 1350g wheels.
Does it have the knot cockpit and stock bar tape and bar end plugs? If so a cheap way to save weight would be to switch the bar end plugs for some push in one's, the ones that come it are surprisingly heavy! Another trick is to leave the tops of the bars unwrapped as long as they're still comfortable for you of course!
I actually prefer to have most of the tops unwrapped. Just took off the tape and plugs. Weighed about 110g. Probably save 30-40g by going to supercaz.
Good idea.
Also, weighed both the Force 10-33 and 10-36, for those interested. 10-33 was 268g and 10-36 was 311g.
So, if I put on new tape and go back to the 10-33, still looking at 7.92kg. Lol.
Hi All
New to the forum so excuse any faux pas - wanted to follow on from this point about the weight of the SS,
I bought a Ultegra Disc 2021 58 (I'm 6ft 3) and love it, apart from the weight but I'm willing to make some investments over time here.
Firstly i cannot understand why the bike weights so much, is it just because its 58 frame, its 8.6kg which is chubby when looking at other SS bikes and claimed weights here. I've created a list to see how it adds up but that still doesn't explain. Can someone help to correct what I'm missing?
Weight Bike
Bike (wheels off) Total 5,650
Cannondale SS Evo 58 Balistec Frame (claimed) 999
Cannondale SS Base Fork (claimed) 436
Cannondale Knot Alloy Stem and Knot Carbon Handlebar 530
Knot carbon Seatpost non offset 170
FSA P2M Powerbox Carbon Crank + spacer 570
Ultegra 8020 Front D. 92
Ultegra 8020 Shifters 554
Ultegra Rear D 200
K11 11speed Chain 255
Ultegra disc brakes x2 286
Disc Brake mount 160mm adaptors Front 11
Disc Brake mount 160mm adaptors Rear 20
Bar tape Cannondale hex 150
Fizik Alliante OEM Saddle 250
Cannondale Saddle Clamp Assembly 61
Light Mount and Light 67
Stock Cannondale Bottom Bracket PF30A (guess) 170
Ultegra R8000 Pedals 250
Cables and Hoses (guess) 200
Headset topcap 4
Garmin Holder 40
Headset Cannondale tapered 100
Elite water bottle cages and bolts 86
More ??? 149
Front Wheel Total (HG35) 1,260
Ultegra freeza Rotor 160mm 130
Corsa G 2.0 Tyre 220
Vittoria Latex Inner 87
Front Wheel Cannondale HG 35 (Rim Spokes Hub) 792
Speed Release Thru Axle 110mm 31
Rear Wheel Total (HG35) 1,691
Vittoria Corsa G 2.0 Tyre 220
Latex Inner 87
105 Rear Cassette 284
Rear Wheel Cannondale HG 35 (Rim Spokes Hub) 929
Speed Release Thru Axle 140mm 41
Total weight 8,601
(Can't work out how to load a picture but this is it (minus FSA cranks)
https://www.rutlandcycling.com/bikes/ro ... MIEALw_wcB
