Are We Getting A New Cannondale Supersix?
Close to pulling the trigger on a SS6 Evo ultegra di2, it would be an upgrade on a Tarmac SL5.
Any direct views or comparable alternatives worth considering, I was going to keep it pretty stock.
Just read a couple of the comments about build quality it would be a MY22 that I would get, should I be concerned?
Cheers
Cheers
I just bought an SS6 Evo HM frame set in rainbow trout, manufactured in May of 2022, seatpost keeps slipping and when it gets warm outside the creaking from the post is horrendous, really spoils what is otherwise an excellent bike. LBS is helping out and will be replace the seatpost, and if that doesn’t solve it, the frame, but it just shouldn’t be like this in the first place.bobodaclown wrote:Close to pulling the trigger on a SS6 Evo ultegra di2, it would be an upgrade on a Tarmac SL5.
Cheers
Sadly this is likely to be my first and last cannondale
On the other had, another friend bought a fully built bike with UDi2 and it’s been perfect for them so
I had the same problem with my Evo until a local Dale dealer explained that (a) the seat post design is poor and (b) the trick is to bash the saddle whilst tightening the clamp, this allows the clamp to fully engage with the seat post as you are 'jostling' it into the correct position.moonoi wrote: ↑Mon Nov 07, 2022 12:26 amI just bought an SS6 Evo HM frame set in rainbow trout, manufactured in May of 2022, seatpost keeps slipping and when it gets warm outside the creaking from the post is horrendous, really spoils what is otherwise an excellent bike. LBS is helping out and will be replace the seatpost, and if that doesn’t solve it, the frame, but it just shouldn’t be like this in the first place.bobodaclown wrote:Close to pulling the trigger on a SS6 Evo ultegra di2, it would be an upgrade on a Tarmac SL5.
Cheers
It sounds odd but the trick has worked for me so far.
- MrCurrieinahurry
- Moderator
Ive also heard of this same technique
Basso Diamante eps 12
Hi all, new to the forum but secretly have been reading a lot of "SuperSix Evo" topics with all positive and negative experiences have purchased the Leichtbau frame very recently, but have to admit, I am still hesitating about this one or a S-Works Tarmac SL7. In terms of pricing the same category, but obviously, you see them everywhere while the Cannondale SuperSix is rather unique here on the Belgian / Dutch roads.
What i am wondering: a lot of guys are complaining about the BB30 bottom bracket. What is the main reason? Has it something to do with the built of the SuperSix frame? Or is the quality of BB30 bottom brackets that Cannondale provides that is not sufficient enough? And that can be solved by for example purchasing ceramic bearrings?
I am a newbie in these kind of topics, so love to hear your thoughts.
"Thank you for taking the time to reach out!
There should be more information on the next generation of the Supersix Evo within the next couple months. We can expect these to arrive at dealers between late Winter and early Spring of 2023. In the meantime, we recommend checking in on our website, social media, and you are always welcome to reach back out here for more updates."
From Cannondale
From Cannondale
Sure, it will come a new one but this bike is soo good. Had a more standard SuperSIX Evo a couple of years ago and my Leichtbau is as fun, just lighter
/jonas l
http://instagram.com/jonaslundb
- MrCurrieinahurry
- Moderator
Surely you have some more pics to post, #tease
Is this someone who is more closely associated with Cannondale Europe and can tell me what frame (paintjob) I will be getting as a warranty replacement?
Unfortunately neither LBS nor the distributor can determine this.
I would appreciate your help!
I found in the post below from @req110 that he received the same model "700 M S6 Evo HM Disc War Frm REP".
The only puzzle is this model code "C11091M". I can't find such a frame anywhere.
MY22 REP Rapha whole purple and pink one is: C11151M
MY23 REP Rapha whole white and pink one is: C11452M
The model 'C11091M' is nowhere to be found online. Is that a code for warranty frameset or something else?
req110 wrote: ↑Fri Feb 26, 2021 4:36 pmreq110 wrote: ↑Sun Nov 01, 2020 11:59 amviewtopic.php?f=3&t=156359&p=1622775#p1622775
Hello guys.
I have this on right side of my headtube, the paintwork is peeling off here.
It should be covered by warranty. "Paint and Decals: One year from original retail purchase."
I have contacted lbs, they told me to bring it and they will send it to distributor. I will do that soon most probably, unless you tell me there is no chance of getting replacement.
Can you guys share with me your experience?
1) is there probability of getting new frameset on RMA?
2) i bought the bike as ultegra kit, but replaced for sram red etap, i hope they won't have any problem with that
3) my frameset is 2020 team replica rapha / if i get new frameset, will they
a) find exact same 2020 team replica
b) replace with 2021 team replica
c) offer me some other hi-mod frameset
d) try to fucc me up with standard mod frameset?
I got new frameset, the my21 team replica, which has the vulnerable place strengthen from the inside opposed to my20 model. Waiting for brake mounting, bleeding, pressing bearings and cutting fork.req110 wrote: ↑Sun Dec 13, 2020 10:00 amI got info from seller that distributor told him, that cannondale will provide me with new frameset.
They told me they reserved this code name. Availability by February 2021.
700 M S6 Evo HM Disc War Frm REP 54
Any of you can decode what exactly it is? I think it should be 2021 rapha replica. (I had 2020 rapha replica), but my understanding is that I would get 2020 immediately, since I have to wait till February it sounds like my2021.
My warranty case was handled with conclusion: This is mechanical damage and is not covered by warranty. For the sake of Cannondale's good reputation, we are going to provide you with new frameset.
I am not dumb of course, i am not pushing steering to the limit. This damage happened for example by leaning the bike while standing and holding the bike just by saddle. So the handlebars/fork/frontwheel automatically turn right... Do it few times and your headtube may get damaged too.
I am waiting for monday till i have my new frameset, then i would call a cannondale service a top notch customer oriented.
C12345 is a model code; M, F or U is male, female or universal; after that there is colour code which is 10, 20, 30 etc... Unfortunately there is no universal rule for colours. I you have whole code including colour code I can try to find out.trex wrote: ↑Tue Nov 08, 2022 9:42 amIs this someone who is more closely associated with Cannondale Europe and can tell me what frame (paintjob) I will be getting as a warranty replacement?
Hello guys.
Dum spiro spero
my bike: viewtopic.php?f=10&t=130302
Does 8.18kg sound about right for a '21 High Mod 58cm with Zipp 302/ Zipp SL stem/ Zipp SL Bar/ speedplays?
Thanks!
The whole code is: C11091M2056
nooski wrote: ↑Tue Nov 08, 2022 10:57 amC12345 is a model code; M, F or U is male, female or universal; after that there is colour code which is 10, 20, 30 etc... Unfortunately there is no universal rule for colours. I you have whole code including colour code I can try to find out.trex wrote: ↑Tue Nov 08, 2022 9:42 amIs this someone who is more closely associated with Cannondale Europe and can tell me what frame (paintjob) I will be getting as a warranty replacement?
Hello guys.
This code was used on warranty frames with 2021 season marking so I believe it will be this one: https://images.mtbiker.sk/eshop/big/119 ... c2a9f.jpeg I am not 100% sure though
Dum spiro spero
There is nothing wrong with PF BB's if they are implemented as designed. The issue is that the PF design is heavily reliant on good manufacturing tolerances, otherwise you get tiny movement and instability which leads to knackered bearings and the dreaded creak. Anecdotally at least, Dale seem to have suffered more than most in a lack of ability to consistently hit good tolerances. So the issue isn't the quality of the bearings going in there, it's the supporting frame around those bearings and whether the bearings are being held perfectly aligned and without movement.Cuypmeister wrote: ↑Mon Nov 07, 2022 8:25 pmWhat i am wondering: a lot of guys are complaining about the BB30 bottom bracket. What is the main reason? Has it something to do with the built of the SuperSix frame? Or is the quality of BB30 bottom brackets that Cannondale provides that is not sufficient enough? And that can be solved by for example purchasing ceramic bearrings?
I've taken to putting a single piece BB into all my PF bikes when I get it (I use BBInfinite but lots of options available), Cervelo seem to have started to shio their bikes with thread together BB's which achieves the same outcome. This removes most of the potential issues. Manufacturers are starting to go back towards threaded BB's as consumers have gotten frustrated and are now expressing a buying preference towards threaded to avoid the hassle.
