After this, i ordered a set of RAP for my 2019 SS EVO. I studied the stock axles to make sure that i order the correct item but didnt think of weighing them first. Axles arrived today. Turns out my stock axles(probably different than Bagelmaster's) weigh a total of 71gr. RAP ones, weigh 63gr as advertised. A bit dissapointed as i was counting on these 50gr savings on my quest for a sub7 bike. Will have to look elsewhere nowBagelMaster wrote: ↑Fri Feb 12, 2021 10:57 pmJust for reference, I saw some mentions of the Robert Axle Project axles. My Cannondale came stock with DTSwiss axles whch weigh in at:
Front: 51.5g
Rear: 62.1g
The Robert Axles Project Axles weigh in at:
Front: 26.5g
Rear: 35.8g
So 51.3g saved. I mostly replaced the stock thru-axles because I get particularly annoyed at the double-lead-in thread. More often than not I end up having to wrangle with the thru-axle because it always wants to end up somewhere around 6 o'clock, which looks stupid to me. It's mostly just aesthetics, but it considering discs are less aerodynamic, at least the RAP thru-axle will be a little more aero than just having it flaccid.
Are We Getting A New Cannondale Supersix?
Hi Dan,Dan Gerous wrote: ↑Thu Feb 18, 2021 4:45 amBottom bearings are different, the IS47 used on the 54cm and smaller bikes are integrated, for 1 1/4", 45° seat angle but I had a quick look around and the 56cm and up are 1 3/8" at the lower bearing, so they probably are IS49 by Cane Creek's Standardized Headset Identification System (see table 2) as that's what the larger Synapse frames also use for the lower bearing. IS52 is too big, it's for 1 1/2" steerers.
Sorry to bother you again, but I can’t quite source the correct headset for my size 56 SuperSix Evo.
This one should probably work as a upper bearing, right? https://www.bike24.at/p1213505.html
But I can’t find a fitting bottom bearing (IS49) as you said. Is there a chance it might be a different bearing?
Thanks in advance for your help.
Cannondale SuperSix Evo Disc
Cannondale SystemSix HiMod Disc
@floriansantana
@floriansantana
- Dan Gerous
That bike24 link is confusing, they say IS41 but that fits IS42, but IS41 and IS42 have slightly different measurments, dIfferent depths and diameters, but maybe they're close enough and can be used with a different compression ring? But this one looks right: https://www.bike24.at/p1315833.htmlfloriansantana wrote: ↑Wed Mar 24, 2021 10:39 pmHi Dan,Dan Gerous wrote: ↑Thu Feb 18, 2021 4:45 amBottom bearings are different, the IS47 used on the 54cm and smaller bikes are integrated, for 1 1/4", 45° seat angle but I had a quick look around and the 56cm and up are 1 3/8" at the lower bearing, so they probably are IS49 by Cane Creek's Standardized Headset Identification System (see table 2) as that's what the larger Synapse frames also use for the lower bearing. IS52 is too big, it's for 1 1/2" steerers.
For the bottom, sorry I don't know much more than that, I never had to source a 1 3/8" headset bearing...
Dan Gerous wrote: ↑Thu Mar 25, 2021 12:17 amThat bike24 link is confusing, they say IS41 but that fits IS42, but IS41 and IS42 have slightly different measurments, dIfferent depths and diameters, but maybe they're close enough and can be used with a different compression ring? But this one looks right: https://www.bike24.at/p1315833.htmlfloriansantana wrote: ↑Wed Mar 24, 2021 10:39 pmHi Dan,Dan Gerous wrote: ↑Thu Feb 18, 2021 4:45 amBottom bearings are different, the IS47 used on the 54cm and smaller bikes are integrated, for 1 1/4", 45° seat angle but I had a quick look around and the 56cm and up are 1 3/8" at the lower bearing, so they probably are IS49 by Cane Creek's Standardized Headset Identification System (see table 2) as that's what the larger Synapse frames also use for the lower bearing. IS52 is too big, it's for 1 1/2" steerers.
Thanks Dan for helping out. It’s really not easy to find a 1 3/8“ headset bearing. Seems to be the unicorn of all bearings.
@floriansantana
@floriansantana
Is this the one you're looking for?floriansantana wrote: ↑Sat Mar 27, 2021 1:14 pmDan Gerous wrote: ↑Thu Mar 25, 2021 12:17 amThat bike24 link is confusing, they say IS41 but that fits IS42, but IS41 and IS42 have slightly different measurments, dIfferent depths and diameters, but maybe they're close enough and can be used with a different compression ring? But this one looks right: https://www.bike24.at/p1315833.htmlfloriansantana wrote: ↑Wed Mar 24, 2021 10:39 pmHi Dan,Dan Gerous wrote: ↑Thu Feb 18, 2021 4:45 amBottom bearings are different, the IS47 used on the 54cm and smaller bikes are integrated, for 1 1/4", 45° seat angle but I had a quick look around and the 56cm and up are 1 3/8" at the lower bearing, so they probably are IS49 by Cane Creek's Standardized Headset Identification System (see table 2) as that's what the larger Synapse frames also use for the lower bearing. IS52 is too big, it's for 1 1/2" steerers.
https://www.cannondale-parts.de/epages/ ... cts/K35038
Happy Days!
Agreed - insta said coming soon so just a placeholder
Hi guys, it seems you have knowledge about the the Hollowgram crankset. I have a question and hope you can help... I bought a SISL2 crank set which I installed on my new SuperSix Evo Hi-mod frame. I followed the instructions and used the spacers for the 73mm BB. I used 3 washers and the preload ring is slightly pressed but I can still move the crankset. When I push on the left crank it moves approx 2mm. I can now add another shim which might solve the issue but the instructions say that I need "1 till 3 shims". Any thougs? ThanksDan Gerous wrote: ↑Thu Mar 19, 2020 6:15 pmOne is marked for the drive side (it's the squarer one) so you need that one. Then there are two different ones for the non-drive-side (tapered shapes), the wider one is for older BB30/PF30 frames with 68mm wide BB shells but the Evo is PF30a (73mm wide sheel) so you need the narrower one marked BB30a/PF30a. Then non-drive-side you'll use the usual wave washer and thin shims to adjust bearing preload.
That doesn't look right, stupd question but what does the drive side look like? I assume you've got the 2.5 spacer on there?
Paint looks great btw...
Thanks for the comment! Yes the drive side has the 2.5mm spacer and then the bearing shield. The wave washer is slightly pressed but I have the feeling that it needs more compression. The only way is adding an extra shim I guess, but there are already 3 shims in between... Thanks again!
