Are We Getting A New Cannondale Supersix?
C36
by C36
As mentioned above, PF shouldn’t have been a problem. Everywhere around you where you have bearings, they are pressfit, that’s engineering 101 (literally the first class in many technical careers).
But cycling industry delocalised and lost control on QC, Cervelo needing to be slapped very hard on the face by cheating increasing their official tolerances “after the fact” way beyond what engineering dictates.
Where I disagree with you
Stueys wrote:Cervelo seem to have started to shio their bikes with thread together BB's which achieves the same outcome. This removes most of the potential issues. Manufacturers are starting to go back towards threaded BB's as consumers have gotten frustrated and are now expressing a buying preference towards threaded to avoid the hassle.
A threaded BB is basically something with huge play so you can screw it and screws are not positioning devices. So you solve poor production tolerance that cause a problem by very wide tolerances that cause less problems but is still a so so engineering solution.
Stueys
by Stueys
C36 wrote:
Wed Nov 09, 2022 4:03 pm
We don't disagree, my preference would be a well made PF solution. But that seemingly appears hard to achieve consistently.
ry5n
by ry5n
I've taken to putting a single piece BB into all my PF bikes
Speaking of which, anyone know which of those one-piece PF30A BBs are the lightest?
C36
by C36
Stueys wrote: We don't disagree, my preference would be a well made PF solution. But that seemingly appears hard to achieve consistently.
Image, I am just waiting to see marketing selling this as an Engineering improvement Image
Not sure how representative it is but we raced on caad6-7 and none had creaking BB. I would point more to QC than metallic frames over carbon (Asian-made Caads had their BB creaking).
RDY
by RDY
Stueys wrote:
Wed Nov 09, 2022 5:11 pm
It's consistently hard to achieve when the price they pay the manufacturer is so small, and they get away with it because the cycling press and circle of 'influencers' are generally even tamer and more sycophantic than exclusively Apple covering publications.
justkeepedaling
by justkeepedaling
C36 wrote:
Wed Nov 09, 2022 6:06 pm
I've not once had any issue with my CAAD 10 bb and I don't clean it or maintain it at all
cerro
by cerro
MrCurrieinahurry wrote:
Tue Nov 08, 2022 5:25 am
Surely you have some more pics to post, Image #tease
Basso Diamante eps 12
Is this better? :D 6,36kg
MrCurrieinahurry
by MrCurrieinahurry
Yes hot damn!!!! But that's some heavy ass bar tape
BigBoyND
by BigBoyND
canterbizzle wrote:
Tue Nov 08, 2022 11:19 am
Does 8.18kg sound about right for a '21 High Mod 58cm with Zipp 302/ Zipp SL stem/ Zipp SL Bar/ speedplays?
Can't help without a build list. What you think might be "minor" parts could be adding a lot of weight. Saddles can easily be 100-300g. Tires and tubes 400-700g. Groupsets 1900-2800g. And so on.
8.19kg can sound about right with those parts but so can 7.19kg.
Cuypmeister
by Cuypmeister
Stueys wrote:
Wed Nov 09, 2022 3:11 pm
Cuypmeister wrote:
Mon Nov 07, 2022 8:25 pm
What i am wondering: a lot of guys are complaining about the BB30 bottom bracket. What is the main reason? Has it something to do with the built of the SuperSix frame? Or is the quality of BB30 bottom brackets that Cannondale provides that is not sufficient enough? And that can be solved by for example purchasing ceramic bearrings?
There is nothing wrong with PF BB's if they are implemented as designed. The issue is that the PF design is heavily reliant on good manufacturing tolerances, otherwise you get tiny movement and instability which leads to knackered bearings and the dreaded creak. Anecdotally at least, Dale seem to have suffered more than most in a lack of ability to consistently hit good tolerances. So the issue isn't the quality of the bearings going in there, it's the supporting frame around those bearings and whether the bearings are being held perfectly aligned and without movement.
I've taken to putting a single piece BB into all my PF bikes when I get it (I use BBInfinite but lots of options available), Cervelo seem to have started to shio their bikes with thread together BB's which achieves the same outcome. This removes most of the potential issues. Manufacturers are starting to go back towards threaded BB's as consumers have gotten frustrated and are now expressing a buying preference towards threaded to avoid the hassle.
Thank you!
tarmackev
by tarmackev
cerro wrote:
Wed Nov 09, 2022 10:00 pm
That's stunning!
CAAD8FRED
by CAAD8FRED
If the new SSE has a triangle shaped steerer, how would one be able to use any after market stem? Someone in this thread said you could use any stem with it and maybe I'm being a bit slow right now, but how would one do that?
Hexsense
by Hexsense
If the triangle is smaller than a regular round steerer tube, maybe using a shim to make it round where the stem clamp?
justkeepedaling
by justkeepedaling
Some type of shim
canterbizzle
by canterbizzle
BigBoyND wrote:
Thu Nov 10, 2022 7:30 am
clearly wrote this in a haze - missed some vital points apologies
it's a mechanical ultegra
oem carbon non setback post
selle italia SLR flow 131mm
continental GP 5000
