Press Fit PF30A
MAJ
by MAJ
Hi guys
I have bought this week a Supersix Evo HM disc frameset and I am going to start my project.
The first concern is the bottom bracket.
I want to reuse the cranckset that I have in my other bike (other cannondale supersix evo, non HM, rim brake, and sram red 10v), that is a Rotor 3D+ with Power2Max and Praxis works chainring.
What do you recomend me in order to save grams?? because I think the principal options in the market are too heavy.
Regards,
MAJ
pocari123
by pocari123
Not sure what options are out there but I think your primary concern should be creaking.
I'm using the cbear pf30a to gxp BB and so far so good. No creaking yet
MAJ
by MAJ
So, your recommendation is this one, isn't it?
https://www.c-bear.com/en/products/pf30 ... rotor-30mm
Other brands I have found are:
-Tripeak (Taiwan brand)
-Kogel (from Belgium)
MAJ
by MAJ
I think the lightest could be the FSA 200-3111 &3112
Weight arround 70/74gr
alcatraz
by alcatraz
Saving grams is going one sided pwm and carbon spider or spiderring.
But if you can't swap the crank then there isn't much you can do. Carbon-ti chainrings?
