Stem angles
Guevarca
by Guevarca
I know I could google but am sure the collective minds here will know...
What stem angles do different brands use?
I currently run matching Deda finishing kit but want a little less height at the front end.
On Deda their stems are -8degrees unless I go Zero 100 Team/Pista which is -20.
I know 3t do a -17 degree but what else is available around -10 to -15 degree range?
Thanks for your help
zirxo
by zirxo
I think all of PROs models is available in -10 and -17 and Zipp SL Sprint is -12. Those are the ones I know about off the top of my head.
Orbital
by Orbital
ITM has a few stems in -10. I have an Alcor on my supersix.
joejack951
by joejack951
Kalloy Uno comes in -17 degree.
Guevarca
by Guevarca
Thanks all, will check them out as don’t want anything quite as severe as the -20
morganb
by morganb
Someone informed me in a similar thread you can get an S-Works stem in -12. They are light and have subtle logos that wouldn't look out of place with a Deda cockpit.
TheDoctor
by TheDoctor
Easton EC90SL is available in -10 too
Scott Addict Premium Disc
Argon 18 Nitrogen
Specialized Tarmac SL4 Pro
Canyon Exceed CF SLX 8.0
Kazyole
by Kazyole
Extralite does the hyperstem in -6° and -12°
wrenegade
by wrenegade
Thomson (X2, X4) also does a -10° and -17°, and the older Easton EA90 stems were available in a -10° (new ones are -7°). The Specialized S-Works SL stem (aluminum) does come in a -12° but I think it's a little hard to come across. It doesn't appear to be available in Canada yet.
cyclenutnz
by cyclenutnz
I haven't updated in a while but this list shows a lot of stem options
https://www.velogicfit.com/fit-essentials/stems/
http://www.speedtheory.co.nz
http://www.velogicfit.com - 3D Motion Capture and Frame Finder Software
Guevarca
by Guevarca
That’s great, thank you
Using a 140mm limits me somewhat but thanks for the info
sychen
by sychen
Zipp service course comes in a 25deg.. Go big or go home!
Sent from my SM-G950F using Tapatalk
Slammed
by Slammed
Pro vibe alloy -10 comes in 140mm. The Zipp sprint sl is probably the only -12 stem that comes in 140mm. You could also go to a lower stack headset upper if you want to go a bit lower with a -8 or -10 degree stem.
