2019 Sram Force ETAP
Does it change depending on what gear you’re in or it is consistent across the range?
it's consistent at least in the upper half of the cassete, and atm a lot more noticeable in the smaller ring in the front... when I'm on the lightest gear it tends to make quite some noise
No aftermarket direct mount rings seen anywhere yet?
Current
Waltly Gravel (stolen... and found!)
P-X Spitfire Ti
Fairlight Strael
Old
Canyon Ultimate SLX 6.7kg (crashed)
Tantan GR039 7.2kg (sold)
P-X Spitfire Ti
Fairlight Strael
Old
It might not be your bb/crankset. If you have another rear wheel you can try, do it and see if the noise goes away. I had a super annoying “squeak” sorta noise in my SRAM AXS setup that sounded like from the bb area and it happened on climbs when using my four biggest cogs. So...lotsa torque being applied. Drove me mad. But...it went away when I switched wheelsets. Thought it might be the cassette, so swapped that out. No luck. Greased the crap out of everything, no luck. Finally it dawned on me it must be in my rear hub. Turns out a rubber o-ring in my hub was the culprit. I have I9 hubs, easy to service. New o-ring, clean and new grease....silence!M4lukz wrote:it's consistent at least in the upper half of the cassete, and atm a lot more noticeable in the smaller ring in the front... when I'm on the lightest gear it tends to make quite some noise
Managed to talk with my LBS, and they sent me a video, with chain off, spinning the cranks, and it was squeaking like crazy... Might ask them to either try to remount everything or go to where I bought it and worst case scenario go for the warranty on the crankset...MattMay wrote: ↑Wed Apr 01, 2020 3:55 pmIt might not be your bb/crankset. If you have another rear wheel you can try, do it and see if the noise goes away. I had a super annoying “squeak” sorta noise in my SRAM AXS setup that sounded like from the bb area and it happened on climbs when using my four biggest cogs. So...lotsa torque being applied. Drove me mad. But...it went away when I switched wheelsets. Thought it might be the cassette, so swapped that out. No luck. Greased the crap out of everything, no luck. Finally it dawned on me it must be in my rear hub. Turns out a rubber o-ring in my hub was the culprit. I have I9 hubs, easy to service. New o-ring, clean and new grease....silence!M4lukz wrote:it's consistent at least in the upper half of the cassete, and atm a lot more noticeable in the smaller ring in the front... when I'm on the lightest gear it tends to make quite some noise
Ah yeah found those, thanks But meant 2x...
Current
P-X Spitfire Ti
Fairlight Strael
Old
P-X Spitfire Ti
Fairlight Strael
Old
Any news on a 1x gravel cassette with ~420-450% range?
I'm buffled that it is not available and 99% sure they do plan something like this, it's just makes so much sense to me. Eagle casette is way too big range (and even bigger jumps as 11s 10-42), the 10-33 is way too small for any terrain thats remotely steep.
I know that garbaruk working on something like this but can't believe that SRAM isn't.
Then there is this mysterious SRAM ZENDESKFAQ entry posted every few weeks without change of content:
https://sram.zendesk.com/hc/en-us/artic ... ded-later-
-Will additional cassette size options be added later?
- SRAM is always working on new product designs but does not comment on products that may be in development
And there is the question weather it will just use the eagle deraillerur or a long caged force/red one?
Anyone anything?
Anyone anything?
I agree that a 420/450% cassette would be perfect for gravel. They need it and would take over the gravel market with it.sebejo wrote: ↑Thu Apr 09, 2020 9:20 amAny news on a 1x gravel cassette with ~420-450% range?
FYI the 10-42 11 speed is identical to the 10-42 part of the eagle cassette. They just added a 50 to it.
Ride fast Take chances
I gave the SRAM guys a hard time on social media about this. I Ended up running a Garabruk 10-48. Interestingly Brad Bingham (Bingham, Eriksen, Moots) just built up a personal bike with RED axs and an XTR 10-45 cassette and said it works great.
I'd be careful with that setup as XTR cassette needs Hyperglide+ chain which needs Hyperglide+ specific chainring which I'm not sure if there is any out there for road cranks.OnTheRivet wrote: ↑Fri Apr 24, 2020 4:24 amI gave the SRAM guys a hard time on social media about this. I Ended up running a Garabruk 10-48. Interestingly Brad Bingham (Bingham, Eriksen, Moots) just built up a personal bike with RED axs and an XTR 10-45 cassette and said it works great.
My bet is also with Garbaruk, they just released a cage+oversized pulley+extender(like roadlink) set for AXS road derailleurs to run up to 52 cog. The point is that the system was designed so that the cage+pulleys - so without the extender - can run up to 42 (or 45) cog cassette with normal 12speed chain. This cassette is not ready yet but they are working on it.
"I'd be careful with that setup as XTR cassette needs Hyperglide+ chain which needs Hyperglide+ specific chainring which I'm not sure if there is any out there for road cranks"
does it though? i run an XTR 12s chain on my Ultegra 11s cassette and Praxis rings and it works just fine.
This article and especially the comment section where Wolftooth and AbsolueBlack are discussing the topic is highly recommended read:scale29 wrote: ↑Fri Apr 24, 2020 5:40 pm"I'd be careful with that setup as XTR cassette needs Hyperglide+ chain which needs Hyperglide+ specific chainring which I'm not sure if there is any out there for road cranks"
https://bikerumor.com/2019/02/28/wtc-s ... bar-lever/
