Ok thanks i will bear that in mindrobbosmans wrote: ↑Sat Jan 08, 2022 9:16 amKeep in mind that sram uses a chain with bigger rollers, if you are using a sram cassette with a shimano chain something will wear out faster than normal
Dura-Ace R9200
Colnago arabesque campagnolo super record 12
Colnago c64
Cinelli zydeco grx di2
Colnago c64
markyboy wrote: ↑Sat Jan 08, 2022 8:55 amThis one ?TobinHatesYou wrote: ↑Sat Jan 08, 2022 8:18 am
SRAM P/N: 00.2018.015.000
I'm guessing where the overshift occurs is dependent on all the factors: chainstay length, derailleur hanger geometry, hanger alignment, etc.
https://www.bikeinn.com/bike/zipp-wheel ... lsrc=aw.ds one?
No. You have a ZR1 hub not a 176 hub. Just Google "ZR1 XDR freehub"
Thanks all doneTobinHatesYou wrote: ↑Sat Jan 08, 2022 9:26 ammarkyboy wrote: ↑Sat Jan 08, 2022 8:55 amThis one ?TobinHatesYou wrote: ↑Sat Jan 08, 2022 8:18 am
Colnago c64
Colnago c64
Just received my C-Bear OCM pulleys anyone running them on there DA9200 derailleur? how are they performing?
S Works SL8 54cm 5.94kgs
Winspace SLC M Ultegra R8150 no idea of kgs
I tried to swap out pulleys to extralite, carbon ones and j&l ceramic, all of the aftermarket ones are much wider than the the stock ones, so the cage doesn’t fit so well and the bolt in some cases isn’t long enough. Interested to see if c-bear fit, if not, will likely just get the Ceramic Speed OSPW cage
Cervelo S3 Disc - 6.78Kg/14.94Ib
Scott CR1 - 5.69Kg/12.54Ib
Scott Addict RC - 6.92Kg/15.25Ib
OnOne - Free Ranger - 8.68Kg/19.1Ib
From what I have seen so far online they appear to fit with no issue.stevec1975 wrote: ↑Sat Jan 08, 2022 2:36 pmI tried to swap out pulleys to extralite, carbon ones and j&l ceramic, all of the aftermarket ones are much wider than the the stock ones, so the cage doesn’t fit so well and the bolt in some cases isn’t long enough. Interested to see if c-bear fit, if not, will likely just get the Ceramic Speed OSPW cage
If they are no good like yourself will probably get the CS OSPW
Also all those videos of the C-Bear spinning freely are the full ceramic models only no grease.
I have the hybrid ceramics £99 with grease let's just say will not be doing any spinning videos however I'm sure they will be an improvement over the original DA
I have no issues with chain wrap capacity when using the 11-30 cassette. I do not have an 11-34 to try and see if it has any issues. I believe it has more to do with shimano worrying about the possibility of the chain contacting the larger chainring when in the smaller chainring and the 11/12 tooth cogs. this was the case on the previous di2 as well.pdlpsher1 wrote: ↑Sat Jan 08, 2022 6:13 amThanks Gavin for the info. I don't own a 12-speed group but your info. is helpful to those experiencing the overshift issue.
If you have a 52/36 with a tooth gap of 16 but entered 54/40 with a tooth gap of 14, will you run into an issue of the RD not having enough chain wrap capacity? I assume you have already tried the big-big and small-small combos. But do you observe the big-big being a little too tight or the small-small being a little too loose? There's probably a good reason why Shimano wanted to lock out certain gear combos and that usually has to do with the chain wrap capacity of the RD.
Lastly, do you see any other chainring combo options beside 50/34, 52/36/and 54/40 in the e-tube app? I ask this because on the Shimano's USA website it lists the top gear teeth capacity of the FD as 46-55. I have wondered if the FD can work with a large ring smaller than a 50. Thanks.
the only chainrings combos listed at this time are the 3 you listed above. this may change as more become available for cyclocross or gravel (grx).
Anyone managed to get the new Carbon TI rings at all?
Also anyone maybe looking at absolute black?
Looking to swap out the 50/34 for either a 53/52 with 36
I've got an order in with them but they're not back in the office until Monday.
Shout if you want to be added since get cheaper than online
IG: RhinosWorkshop
IG: RhinosWorkshop
Question the jockey wheels on the derailleur are they the same size as the older 9100?
As I don't have the older one to compare im hoping someone else will know, im sure I seen somewhere that the pulleys on the 9200 series are slightly bigger
