11-30 Ultegra for me with Dura Ace groupset.BdaGhisallo wrote: ↑Sun Jun 19, 2022 4:48 pmForgive me for not going back and looking for each post describing the issue, but which cassettes are folks having shifting issues with?
Are they DA? Are they Ultegra? Are they a particular size? Are the issues irrespective of that?
Next generation of Dura-Ace Di2
Ultegra groupset with 11-34 ultegra cassette and dfour powermeter with dura ace Rings 50/34!BdaGhisallo wrote: ↑Sun Jun 19, 2022 4:48 pmForgive me for not going back and looking for each post describing the issue, but which cassettes are folks having shifting issues with?
Does anyone know if the DA 11-28 cassette will make it to market? I see some places still listing it as an option but Shimano seem to have removed it from their site.
Might it be a regional item, like the rim brake tubular wheels?
FWIW, Recon do an 11-28 cassette with the same cogs as the now abandoned DA9200, amongst others:
https://www.recon-harry.com.tw/products_detail/1/1/45
DA 9200 plays nice with Absolute Black 52/36 oval 11 spd. chainrings. Oval rings are never going to shift perfectly because of the variable front derailleur cage gap to the chainrings, but the DA 9200 front mech. is shockingly good. WIth SRAM mechanical and Etap, you gotta practice to nail the perfect torque and cadence for good shifting with oval rings, and then it does work well. But with DA 9200 it just works every time without paying any attention. I've always had a love/hate relationship with ovals, but now I don't hate. The bike previously had mechanical Red HRD, and the before/after weight is exactly the same - 7.2kg. Everything is silent as
children trust me
Maybe it’s a supply issue thing, but included pads are all over the place it seems.mistap wrote:I just got round to pulling my pads as my front is rubbing. They are K03TI pads. So what is the standard here? or are they named differently for different markets? or is LO5A the same as KO3TI
Thanks
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
Definatly seems some got the ones with fins and some got the ones without !kode54 wrote: ↑Thu Jun 23, 2022 3:15 pmMaybe it’s a supply issue thing, but included pads are all over the place it seems.mistap wrote:I just got round to pulling my pads as my front is rubbing. They are K03TI pads. So what is the standard here? or are they named differently for different markets? or is LO5A the same as KO3TI
Thanks
CS-R9200 11-28T got cancelled?satanas wrote: ↑Tue Jun 21, 2022 1:21 amFWIW, Recon do an 11-28 cassette with the same cogs as the now abandoned DA9200, amongst others:
That seems to be the word. Too bad. That and a 52-36 would have been perfect for my needs.StiffWeenies wrote: ↑Thu Jun 23, 2022 6:45 pmCS-R9200 11-28T got cancelled?satanas wrote: ↑Tue Jun 21, 2022 1:21 amFWIW, Recon do an 11-28 cassette with the same cogs as the now abandoned DA9200, amongst others:
Anyone see any issues using the new 12sp Dura-Ace crankset with an otherwise 11sp groupset? Which chain to use on such a setup? 11 or 12? I've seen good feedback on going the other way around with an 11sp crankset on a 12sp groupset because of the lack of availability but I actually have just the crankset and would like to use the 4iiii that I had installed on it.
Ultegra 11-34RBdaGhisallo wrote:Forgive me for not going back and looking for each post describing the issue, but which cassettes are folks having shifting issues with?
1. With dura Ace 9100 crank
2. With Rotor aldhu+chain ring
Both 50/34
No 1 have double shift problem, only when multishift enable
Both little noisy oN casette no matter i setup and trim, and when back pedaled it little stutter every few link
Tried change chain to kmc 12sp dlc, no luck. Worse stutter, so i go back with 8100 chain (which have really bad coating its show rust already)
All problem above i never experience on 11sp di2
And that really annoying, especially double shift
Specialized SW Æthos (2021) 6.1kg
Specialized SW Crux (2022) 7.9kg
Specialized SW Tarmac (2022)
Cervelo P5 Disc (2021) 9.1kg
*all weights are race ready bikes, large frame size.
Sold: Venge, S5 Disc, Roubaix Team, Open WI.DE, Émonda, Shiv TT Disc
Oh wow, what was the wait time on that crank?
Moots Vamoots RSL (2019)-Super Record 12
Cervelo S1 (2010)-Super Record 12 (viewtopic.php?f=10&t=161577)
Kestrel RT700 (2008)-Dura Ace 9000
Mosaic GT-1 (2020)-GRX Di2
