Dura-Ace R9200
slake21
by slake21
The Rides of Japan guy weighted the components
alexneumuller
by alexneumuller
Great news and bad news.....
Great: two groupsets to be delivered tomorrow to me.......
Bad: I don't actually have the frames I want to install them on.......
3T Exploro - Bastion - Baum - Colnago - Cielo - English Cycles - Enve - Festka - ISEN - Standert - Open - Pegoretti - Pinarello - Specialized - Sturdy - Stinner - Spoon - Speedvagen - Vanilla Classic - Parlee
Strava
Instagram
ipenguinking
by ipenguinking
alexneumuller wrote:
Tue Nov 23, 2021 6:32 pm
I might have the same problem in 2 months. I also need new wheels. I was told those new DA wheels won't be available until next summer.
slake21
by slake21
ipenguinking wrote:
Tue Nov 23, 2021 6:35 pm
German webshops had the new wheels for weeks
wheelsONfire
by wheelsONfire
Hm, are you hellbent on those wheels or can you imagine something else?
Bikes:
Open *UP* (2016.04.14)
ipenguinking
by ipenguinking
wheelsONfire wrote:
Tue Nov 23, 2021 7:55 pm
No but I do like their $2100 msrp in the US. Maybe I'll get a set of WTO for the build and covict the fashion violation?
BigBoyND
by BigBoyND
ome rodriguez wrote:
Mon Nov 22, 2021 2:05 pm
More photos
Would have preferred 52/36T, but this pandemic you don't get to choose.
What is the yellow part?
It looks like the complete kit comes with some tools (i.e. wire tool). If I order components separately, will they come with the parts? I don't need the cranks or rotors, so ordering separately makes more sense for me.
Also does anyone know if the RD includes the charger?
I'm trying to figure out what I need to order beyond components. I've never installed or serviced hydraulic brakes or electronic groups. I have all the tools to install mech Shimano parts.
Maddie
by Maddie
The yellow part is a piston blocker when you transport the bike without wheels or when you bleed the brakes. You need to remove brake pads and push the pistons back in order to get the blocker in place.
RD doesn't come with a charging cable. Which makes sense because if you need a spare RD you'd also get another cable that you don't need. The cable is less expensive than the old charger.
BigBoyND
by BigBoyND
Maddie wrote:
Wed Nov 24, 2021 5:45 am
Excuse my ignorance, I'm learning. I thought you just put the red one in when traveling, with pads in place. Why remove pads and use the yellow ones?
Maddie
by Maddie
Of course you can also use the red parts with the brake pads installed. I prefer to use the yellow blockers when I transport the bike, for instance in a plane. Because I like to do a quick bleeding and with the yellow part already in place, it's just ready for that. For a short transport, this of course is not really necessary.
phillyt1988
by phillyt1988
My local bike shop have just posted they have the groupo's in stock now: https://www.hargrovescycles.co.uk/compo ... /groupsets
stevec1975
by stevec1975
phillyt1988 wrote:
Wed Nov 24, 2021 1:58 pm
Thanks so much for the heads up! just ordered, coming tomorrow!
I will be selling the crank (172.5 with 52/36 Rings) and the 2 x 140mm XTR Rotors, if anyone is interested.
ccparkhill
by ccparkhill
stevec1975 wrote:
Wed Nov 24, 2021 2:56 pm
I'd be interested in one of the rotors, am also in London.
thebikemanguy
by thebikemanguy
I'm pretty sure I've read that it works already in this thread, but just wanted to confirm that 11-speed cranks work with the 12 speed groupset?
ooo
by ooo
some (a few) shifters fails pair, this can be fixed with new di2 update:
https://api.shimano.com/etube/public/data/upload/published/E-tube_Proj_V_5_0_2.zip
https://bike.shimano.com/en-EU/e-tube/project.html
It has been confirmed that pairing the rear derailleur with the dual control lever fails for some units when the version of the firmware on ST-R9270/ST-R8170 is Ver. 4.0.2 or earlier.
If pairing fails, use one of the following applications to update the version of the firmware on ST-R9270/ST-R8170 to Ver. 4.0.3 or later.
* Follow the steps below to update the firmware using E-TUBE PROJECT Professional Ver.5.0.2 or later or E-TUBE PROJECT Cyclist Ver.5.0.2 or later.
* Use SM-PCE02 to connect the dual control lever to your PC with a cable and update the firmware, then perform pairing.
* Customers who do not own SM-PCE02, contact your place of purchase or a distributor for assistance.
* Connect the rear derailleur to the dual control lever with a cable and update the firmware, then perform paring.
it looks you can fix this with sm-pce02 in workshop or
you can try to use wireless app connected to battery + wired connection from battery to hydro shifter (extra di2 wire)
