Dura-Ace R9200
pdlpsher1
by pdlpsher1
I had to modify my existing cage to get rid of the noise. I made it thinner and added a chamfer. I didn’t want to wait for a new cage.
BLUTACK
by BLUTACK
BLUTACK wrote:
Wed Mar 29, 2023 10:13 pm
Can you use new Dura Ace crankset with old 11 speed chain etc? Wanting to switch from 175 cranks to 170 and with dual power meter.. cannot get stock of 4iii or Stages in older 9100 model, only the newer version. I believe that the older 9100 dual sided 4iii and Stages were not that great anyway (?).
Anyone? Apologies if this has been answered previously - I couldn't find anything in the search function
LedZeppelin007
by LedZeppelin007
They ever fix the weird issues with the 11-34t cassettes?
MarcFaFo
by MarcFaFo
BLUTACK wrote:
Thu Mar 30, 2023 10:06 pm
For what it is worth. I am running a DA9200 Stages L/R on my full Di2 Ultegra 11 speed set-up, ie FD and RD both are 11 speed. Chain is Ultegra 11 speed. Works without any problem sofar. Ridden 4 rides total of 350km's (including 3 races of 45km each and the ride to the track)
petal666
by petal666
MarcFaFo wrote:
Mon Apr 03, 2023 6:41 pm
So you've not really got that much experience with it yet then. 10hrs is not much testing.
X5SAE
by X5SAE
BTW the new version DA derailleur already has the modified backplate installed:
Road
Cube Agree C:62 SLT 2021 (frame+fork) DA 9270 6.9x kg - ride-ready 7.25 kg w/pedals, cages, sensors, Wahoo mount
Gravel
Velobuild GF-002 Force AXS 7.5 kg, ride-ready 7.775 kg w/200 ml Stan‘s, pedals, cages, sensors, Wahoo/Cateye mounts
BLUTACK
by BLUTACK
petal666 wrote:
Mon Apr 03, 2023 11:30 pm
Yes, but still helpful to know.
jayjay
by jayjay
How do you guys take out the batteries from the STI?
I was only able to do it with a plier.
TerryDi2C
by TerryDi2C
Push the battery down a bit and it should come out OK.
If your finger is sliding off the battery, you can also use a bit of tape to get some more grip.
At about 1:00 I take out the battery.... it's hidden from view though. Sorry 😅
https://youtu.be/WEHEN5ihSAk
Beancouter
by Beancouter
If anyone interested, DA v Ult (with Ti clamps) compared.. 12 grams difference!
kode54
by kode54
Not much difference!
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
DanielNorway
by DanielNorway
Hi, a bit late to the party.
Installed a complete r9200-groupset 52-36, 11-30.
Im getting a pretty bad grinding noise when applying power(500W+) in big chainring and on the 2-3 biggest cogs on the cassette.
My initial thought was FD rub, but adjusting it inwards didnt help.
I know cross-chaining like that isnt advised, but sound does not seem normal..
Anyone experienced something similar?
BLUTACK
by BLUTACK
DanielNorway wrote:
Sun Apr 09, 2023 7:38 pm
Adjust the height of your RD - either that or your chain is too small.
biglmbass
by biglmbass
LedZeppelin007 wrote:
Mon Apr 03, 2023 3:55 pm
What issue is that?
Vuong05
by Vuong05
biglmbass wrote:
Tue Apr 11, 2023 3:13 am
What issue is that?
I think he is referring to the "clicking/ticking" noise while on the 5th cog or near the middle of the cassette?
Current Stable. Evo (Storm Trooper) : 5.39kg | Alchemy Eros : Heavy (7.25kg) I Specialized Allez Sprint 2022 : Heavy (7.62kg)
