Dura-Ace R9200
- ArtifactsInMotion
- Contact:
Highly unlikely given that the max cassette size is 34 for DA9200. At best, it works with a rough shift between 31-36. At worst, it breaks the RD trying to make it work. Maybe with a custom long-cage, which isn't out of reason given the current trend towards customizing your RD which simply wasn't even a consideration outside of drillium a couple years ago.
'22 Orbea Orca Aero 57cm, DA92, Bontrager RSL62, GP5KSTR 28mm, Roval Rapide Cockpit, SLR Superflow Carbonio, 7.8kg
Shimano is always conservative.. it has a good chance of working.ArtifactsInMotion wrote: ↑Wed Dec 01, 2021 3:13 amHighly unlikely given that the max cassette size is 34 for DA9200. At best, it works with a rough shift between 31-36. At worst, it breaks the RD trying to make it work. Maybe with a custom long-cage, which isn't out of reason given the current trend towards customizing your RD which simply wasn't even a consideration outside of drillium a couple years ago.
9000RD was 28T.. I could do 32 on some frames
9100RD ofocurse no issues doing 32
9200RD spec'd to 34.. I'd bet 36 works.
Hell even my AXS Red (non wide) RD does 36t
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
Quite the interesting setup - xplr 10-36 + 48/33 + 9200. It would be a great gravel setup...
https://www.instagram.com/p/CW7Hc6iF_p2 ... =copy_link
ccie6872 wrote: ↑Wed Dec 01, 2021 5:38 amQuite the interesting setup - xplr 10-36 + 48/33 + 9200. It would be a great gravel setup...
Nitpick, but the 10-36t isn't an XPLR part. It was introduced with Force AXS Wide.
TBH 33x36t isn't good enough for the "gravel" over here on the US West Coast, though I suppose it would be just fine for US Midwest gravel.
Long shot, but anyone used the new KMC X12 chain with 9200? Always preferred the DLC versions over the Shimano chains (and yes, I know they are both made by KMC)
https://www.kmcchain.eu/KMC_12-speed_NE ... ufacturers
Cervelo S3 Disc - 6.78Kg/14.94Ib
Scott CR1 - 5.69Kg/12.54Ib
Scott Addict RC - 6.92Kg/15.25Ib
OnOne - Free Ranger - 8.68Kg/19.1Ib
- robbosmans
- Moderator
- Contact:
Use the shimano chains, hyperglyde + only works with shimano chains.
Kmc x12 also doesn’t last
- robbosmans
- Moderator
- Contact:
Miche has one but its junior gearing 14-29
