Of course.gSporco wrote: ↑Fri Jan 28, 2022 2:18 amPlease post actual weight when you get them.. with valves and stem as well if you plan to run tubelessipenguinking wrote: ↑Thu Jan 27, 2022 8:34 pmI just received email from Competitive Cyclist that my R9270 C50 wheels are shipped. I placed order when new DA was introduced last August.
Thanks!
Dura-Ace R9200
Shimano site indicates 9270 C50 wheels came with E-Thru Axle technology and the 'axle fixing method' is 12mm E-Thru. Can someone tell me what does this mean? Do I need different thru-axle to fit these wheels on my frame (142x12) and Enve road fork? Both already came with 'factory' TA. Thanks.
Every TA that’s 12mm and fit for your frame will do.ipenguinking wrote:Shimano site indicates 9270 C50 wheels came with E-Thru Axle technology and the 'axle fixing method' is 12mm E-Thru. Can someone tell me what does this mean? Do I need different thru-axle to fit these wheels on my frame (142x12) and Enve road fork? Both already came with 'factory' TA. Thanks.
Cannondale SuperSix
Shimano 9270
Shimano 9270
You can send your crank for factory install, I did it with my 9200 left crank (at 4iiii) and it took about two weeks overall.
The readings are very close to my Neo 2T once calibrated
E-Thru is Shimano's tool-less thru axle design which has a cammed lever that works like a traditional QR to lock the axle in place. While the diameter of the thru axles are the same, I think Shimano e-thru axles have a 1.5 mm thread pitch so if that is different than your frames current thru-axles, then the E-Thru would not be compatible.TurboKoo wrote: ↑Fri Jan 28, 2022 6:19 amEvery TA that’s 12mm and fit for your frame will do.ipenguinking wrote:Shimano site indicates 9270 C50 wheels came with E-Thru Axle technology and the 'axle fixing method' is 12mm E-Thru. Can someone tell me what does this mean? Do I need different thru-axle to fit these wheels on my frame (142x12) and Enve road fork? Both already came with 'factory' TA. Thanks.
- Michael
But mounting the tire with TA that works with the frame should be ok right? Just as TurboKoo said.ms6073 wrote: ↑Fri Jan 28, 2022 4:56 pmE-Thru is Shimano's tool-less thru axle design which has a cammed lever that works like a traditional QR to lock the axle in place. While the diameter of the thru axles are the same, I think Shimano e-thru axles have a 1.5 mm thread pitch so if that is different than your frames current thru-axles, then the E-Thru would not be compatible.TurboKoo wrote: ↑Fri Jan 28, 2022 6:19 amEvery TA that’s 12mm and fit for your frame will do.ipenguinking wrote:Shimano site indicates 9270 C50 wheels came with E-Thru Axle technology and the 'axle fixing method' is 12mm E-Thru. Can someone tell me what does this mean? Do I need different thru-axle to fit these wheels on my frame (142x12) and Enve road fork? Both already came with 'factory' TA. Thanks.
Correct but where are you located ? Not so keen on sending my cranckarm from Belgium to Usa and back. ...IanisCercariolo wrote: ↑Fri Jan 28, 2022 9:13 amYou can send your crank for factory install, I did it with my 9200 left crank (at 4iiii) and it took about two weeks overall.
Is there a central EU install point for either 4iii or stages ?
4iiii will you send you a shipping label from Fedex when you order onlinecarborush wrote: ↑Fri Jan 28, 2022 7:48 pmCorrect but where are you located ? Not so keen on sending my cranckarm from Belgium to Usa and back. ...IanisCercariolo wrote: ↑Fri Jan 28, 2022 9:13 amYou can send your crank for factory install, I did it with my 9200 left crank (at 4iiii) and it took about two weeks overall.
Ok where in the world are youIanisCercariolo wrote: ↑Fri Jan 28, 2022 9:13 amYou can send your crank for factory install, I did it with my 9200 left crank (at 4iiii) and it took about two weeks overall.
4iii U.K. only have option for 9100 left hand at the moment
Unless you selected the 9100 and just sent in the 9200?
S Works SL8 54cm 5.94kgs
Winspace SLC M Ultegra R8150 no idea of kgs
Yes, using your exising thru axle with the new wheels will work just fine.ipenguinking wrote: ↑Fri Jan 28, 2022 5:00 pmBut mounting the tire with TA that works with the frame should be ok right? Just as TurboKoo said.
- Michael
Has been asked a million times, sorry.
11-34 super record cassette compatible with DA9200?
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
I'm in Switzerland and I saw the option for R9200 since November 2021, it seems available on the UK site too : https://4iiii.com/gb/products/pdp/left- ... y-install/Sanders2177 wrote: ↑Fri Jan 28, 2022 9:30 pmOk where in the world are youIanisCercariolo wrote: ↑Fri Jan 28, 2022 9:13 amYou can send your crank for factory install, I did it with my 9200 left crank (at 4iiii) and it took about two weeks overall.
