Dura-Ace R9200
LedZeppelin007
by LedZeppelin007
Does anyone else kind of miss R9100?
m3bas
by m3bas
LedZeppelin007 wrote:Does anyone else kind of miss R9100?
Love the new hoods and no brake rub. But noisy RD and almost never dropped a chain on 9100, now it’s a fairly regular occurrence
jayjay
by jayjay
Wed Jan 25, 2023 1:55 am
You can always go back to R9100 :)
Jz91
by Jz91
It's not so easy it seems...
I was toying with the idea of upgrading from ultegra 6800 di2 to DA 9100 di2 for rim and it seems cheaper to find 12 speed stuff nowadays (EU market).
ultimobici
by ultimobici
Jz91 wrote:
Thu Jan 26, 2023 10:35 am
I have most of what you'd need. PM me if interested
ODC
by ODC
Yes i do.
Although i have bigger hands (i’m 1m93) i like the shape, off the R9100, shifters more.
It was more quiet, no rattling chains issues, no cassette problems, front derailleur had limit screws and never had a single chain drop.
Yeah it’s maybe faster shifting in front and rear but that the most important thing in the world?
For all the above reasons I changed to a single speed Sram Red AXS. Apart from the shifters (still prefer the R9100 above anything) and marginal little bit slower shifting it performs better and is it more quiet (at this moment). Can’t speak about the front derailleur.
Now i speak about my own personal experience and problems. I can believe that there are people with 0 issues.
sealucky
by sealucky
not at all if we are talking about disc version
sealucky
by sealucky
Most of my problems were from the wrongs chain length and the incorrect b-screw position
robertbb
by robertbb
sealucky wrote:
Fri Jan 27, 2023 5:26 pm
What was wrong with the disc version of 11sp di2?
ultimobici
by ultimobici
robertbb wrote:
Fri Jan 27, 2023 11:24 pm
Nothing at all.
Xabi
by Xabi
Calipers rubbing? Fixable with new gen Shimano calipers, trickstuff, campagnolo or magura ones.
STUB1
by STUB1
Hey guys,
I'm just waiting to get my bike rebuilt with 12 speed - who I consider a very reputable/skilled mechanic mentioned to me that I should run it wired rather than wireless. He reckons the shifting is faster when set up wired rather than semi wireless and adding 1 small cable that can run with the hydraulic line it was worth doing. Has anyone else heard this? I can't find it mentioned anywhere (not that I would expect all the press releases to mention it)..
Maddie
by Maddie
No, it's not faster when wired but the battery lasts longer. You'll need at least two additional wires, not just one.
Installation itself is easier if you don't have to route one cable from the BB to one shifter and another one from shifter to shifter.
Nickldn
by Nickldn
STUB1 wrote:
Tue Jan 31, 2023 11:45 am
Hey guys,
This may be a little unfair/judgemental, but this is how I read your mechanic's comment:
(....) who I consider a very reputable/skilled mechanic mentioned to me that I should run it wired rather than wireless. He reckons he could charge you more money to set up wired rather than semi wireless and adding 2 expensive cables that can run with the hydraulic lines it was worth doing. :D :D
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
raggedtrousers
by raggedtrousers
I don't specifically miss the rim brake version of 11 speed, but I do miss the 'it just worked' factor. Neither I nor 2 different shops can totally eliminate chain throw with the 8170 FD, and I preferred the old hood shape.
I'm very seriously considering selling it and seeing if I can pick up 11sp DA for the same money. I did consider AXS, but decided that's too drastic :wink:
