Dura-Ace R9200
The general all-things Road forum!
trex
by trex
Just to be 100% sure - anyone installed the original dura ace carbon cage in ultegra RD?
Is it safe to do so?
cleanneon98
by cleanneon98
trex wrote:
Tue Dec 10, 2024 11:12 am
Numerous people have, there's a thread about it here I think titled something like 105 upgrades. I did it to mine and it works just fine
Edit: viewtopic.php?t=175257&start=45
storcky
by storcky
DA 9200 > Ultrgra 8100 swap works flawless
Ritxis
by Ritxis
storcky wrote:
Thu Dec 12, 2024 9:53 pm
9100/8000 cages also work in 9200/8100 derailleurs... I put a 9100 in my 8150 and no problems
pmprego
by pmprego
It may already have been asked, I'm sorry in advance.
Can the da 9200 allow for a 11-36T cassette? Unofficially of course.
iamraymond
by iamraymond
I have the R8100 RD with the shorter 9200 cage and this setup works with the 11-36t 105 cassette.
pmprego
by pmprego
iamraymond wrote:
Tue Dec 17, 2024 11:46 am
Thanks
satanas
by satanas
Thank you - I was wondering about this also.
On a related note, has anyone tried any of the 12 speed Shimano RDs with a cassette smaller than 11-30? There are options down to 11-25/26/28, 12-29, etc, from various sellers. If either the E Dubied or Recon 12-29 cassettes shift okay I'd be strongly tempted to get one.
OtterSpace
by OtterSpace
There were unreleased 12s Shimano 11-28 cassettes so capacity wise I wouldnt be too concerned with going down to that preferably on the shorter Dura-Ace cage. Also in general Shimano's stated specs are fairly conservative and you can go one step up or down from their recommendations without too much issue. If the alternative cassette itself is up to Shimano shifting quality is another matter though from if the RD can support it.
Tifosiphil
by Tifosiphil
Anyone have any preferred tweaks on their 12s Di2 setups?
Currently converting my all-road bike over as I've been running an 11s Dura Ace/GRX mix. Got R7150 shifters and the battery and an Ultegra cassette and Dura Ace chain ready to go.
Any reason to go for Ult/DA on the derailleurs over 105?
Eterna7m
by Eterna7m
Tifosiphil wrote:
Wed Dec 18, 2024 10:28 am
Big calves and small stance for the FD 😬
Tifosiphil
by Tifosiphil
Eterna7m wrote:
Wed Dec 18, 2024 11:05 am
Interesting, I hadn't considered that. May be worth the extra £50!
I have generally smaller calves (only 70kg) but I do use this bike for cyclocross and gravel racing so the opportunity to have the extra clearance is always welcome
satanas
by satanas
OtterSpace wrote:
Wed Dec 18, 2024 3:34 am
There were unreleased 12s Shimano 11-28 cassettes so capacity wise I wouldnt be too concerned...If the alternative cassette itself is up to Shimano shifting quality is another matter though from if the RD can support it.
Yes, I was aware of the canned 11-28 but IIRC Shimano have omitted it from recent RD specs. I'm not necessarily fussed about "Shimano shifting quality" as long as shifting is reliable and consistent, something there's not much agreement about here. I think one or two people have said the E Dubied cassettes are okay, but nobody has had anything good to say about Recon - which appear near-identical from pics.
OtterSpace
by OtterSpace
satanas wrote:
Wed Dec 18, 2024 11:28 am
Correct. Also I have not tried it myself but just a few posts up people are saying the 9100 cage works with Dura-Ace & Ultegra 12s rd body. This cage is a ss short cage that technically maxes out at 11-30 so might be shorter than 9250 cage. However I think its more paralellagram design and b-screw adjustment that helps cassette size matching.
I'm currently investigating the 3rd gen SLR "aftermarket cassettes" & the specific one I have to test is an 11-34 ZTTO which I am comparing to a 11-34 Dura-Ace but I havent ridden it yet as I just got it this week. It seems like their design branched from SRAM 11s so shifting is likely good enough for what you are looking for. I personally wouldnt use any cassette with Al cogs on smaller cogs as wear life will just be terrible, I'm not sure if recon falls into this type but I know they have made full Al cassettes in the 11s era.
satanas
by satanas
Agreed about alu cogs, and also the few I used (briefly) in the distant past lacked any useful tooth shaping so shifted poorly - worse than Shimano UG. Both Recon and E Dubied do monoblock steel cassettes, which are the ones that would interest me, along with the similar appearing but cheaper ZTTO/Goldix cassettes. When Shimano went to 12 I was really hoping there'd be a 12-28 option (basically combining the 11 speed 12-25 & 12-28) but no dice.
