Next generation of Dura-Ace Di2
gSporco
by gSporco
MattBeOne wrote:
Fri May 20, 2022 10:04 pm
Can anyone point out how to adjust the free stroke for the 12sp Shimano groupsets?
Can't seem to find anything online...
Underside of the lever there is small opening for an Allen wrench..
Here is the page in the manual: https://si.shimano.com/#/en/iDM/RADBR10 ... ADJUSTMENT
@gSporco - Instagram
Specialized Aethos
State All Road 6061
Retired Cervelo Aspero
satanas
by satanas
Someone mentioned Recon cassettes for Shimano 12, but there wasn't much info at the link. On Recon's website they list not two but five sizes, some in different colours. There are the two current Shimano sizes (11-30 & 11-34), plus the projected 11-28, all with the same intermediate cogs as Shimano, plus 11-29 & 11-32 which have the same intermediate cogs as Campag 12.
https://www.recon-harry.com.tw/products_detail/1/1/45
Perhaps they might get around to offering other sizes if there's demand, like say 12-28/29 or 11-36, etc.
ichobi
by ichobi
Anyone weights that 9200 chain ring? I couldnt really find the weight online anywhere. Shimano doesnt specify specific ring weight only in combination with cranks.
50/34 and 52/36 anything you got.
I am contemplating the thm crank for my incoming 12spd da di2 but not wanting to go carbon ti rings route. If the da rings are sufficiently light then i might as well use them.
ricerocket
by ricerocket
satanas wrote:
Sun May 22, 2022 6:47 am
I'm guessing you'll lose Hyperglide+, which is totally not worth the 35g.
In my opinion, it's the best improvement Shimano has made w/ this groupset.
pdlpsher1
by pdlpsher1
ichobi wrote:Anyone weights that 9200 chain ring? I couldnt really find the weight online anywhere. Shimano doesnt specify specific ring weight only in combination with cranks.
They should be the same as the 9100 rings, which are pretty light.
P2M came out with a new lightened four bolt PM. Pair that with Rotor Aldhu carbon arms and 9200 rings should give you a light setup. The problem is the unavailability of 9200 rings.
Dorpel
by Dorpel
I installed the new R8150 but my disc brakes are squeeling like hell. Rotors and pads are perfectly clean. Anyones else having this issue?
pamoreira
by pamoreira
ricerocket wrote:
Sun May 22, 2022 8:01 am
Not only it's lighter, it's much cheaper than DA - that's also a very relevant factor to consider when pondering how much is Hyperglide+ worth.
ricerocket
by ricerocket
pamoreira wrote:
Sun May 22, 2022 4:35 pm
$250 versus $300 USD isn't that much cheaper.
BdaGhisallo
by BdaGhisallo
With the 12sp drivetrains, is there still the option in the E-Tube software to switch off the 'gear control' - the feature that stops you shifting into the two smallest cassette cogs when on the small chainring? If it's there, is it chainring size dependent, as it is with the 11sp setups?
K4m1k4z3
by K4m1k4z3
BdaGhisallo wrote:
Sun May 22, 2022 5:00 pm
You can absolutely shift into those gears. I use it all the time when storing the bike. No need to set up anything IIRC. 52/36 + 11/30 R8100.
2022 Specialized Tarmac SL7 Expert | Ultegra R8100 | Roval Alpinist CL
2019 Specialized Diverge E5 Comp | 105 R7000
2018 Specialized Epic HT Comp Carbon | SRAM GX 1x11
2018 Giant TCR Advanced Pro 1 Disc | Ultegra R8000
BdaGhisallo
by BdaGhisallo
K4m1k4z3 wrote:
Sun May 22, 2022 5:02 pm
Thanks.
pmprego
by pmprego
Three questions for people here with experience in these things:
- Besides weight and price, any performance differences between r8170 (ultegra 12spd) and r9200 (DA 12spd)? I've noticed r9200 uses a one-piece caliper while r8170 uses a two-piece one.
- If one was to mix r8170 with r9200 components and trying to be very conscious of final price, what would be the end result that people here recommends?
-- I've noticed that the calipers give an interesting weight saving. The problem is getting the calipers in r9200 alone. It seems way more common to see listings for shifter+calipers coupled together.
-- The cassette is also a good weight saving and given that I use two different wheelsets (training and racing) I was considering the r8170 for the training wheels and the r9200 for the racing wheels.
- W.r.t. the crank are there any NON-power GXP option as an interesting alternative to the heavy shimano cranks?
JOliver
by JOliver
riochang, did you try to mount the DA chainrings to the clavicula crank ... will they fit? I was considering the same carbon ti evo / clavicula setup, but then saw your post about the decrease in performace. Thanks for sharing your experience, it is very helpful
ultimobici
by ultimobici
pmprego wrote: W.r.t. the crank are there any NON-power GXP option as an interesting alternative to the heavy shimano cranks?
Why on earth would you want a GXP crankset?
Discodan
by Discodan
Errr, “as an interesting alternative to the heavy Shimano cranks”?
