I have issues with Clavicula SE and 12 speed Praxis Buzz chainrings. I had it twice at the mechanic, he tried to carefully adjust chainline, checked the position of shifters, quicklink etc. and still it sends the chain out of the big ring at 50/11. Everything else besides cranks/chainrings is Ultegra 12 Di2 Disc. Bike is Emonda. Besides 50/11 it seems to work nicely. Now I am clueless what to adjust besides buying Shimano cranks. The mechanic suggests buying Sram XX1 chain, he says it is more tolerant.tmanley wrote: ↑Wed Jun 08, 2022 8:24 pmNo issues with my Rotor Aldhu cranks w/ round rings. However, I couldn't get the oval rings to work for me very well.NHWhites wrote: ↑Wed Jun 08, 2022 2:04 amHi all,
Apologies if this has been answered already. I couldn't find anything on it.
Does 8100/9200 FD shift well (up to big ring, down to small ring) with non shimano cranks and rings like Easton, praxis, etc? I had read somewhere that 8100/9200 cranks have their chainrings closer together and wasn't sure if that really mattered.
Thanks so much
Dura-Ace R9200
Anyone looking for a power meter groupo? LBS is showing them in stock with normal crank lengths:
https://www.hargrovescycles.co.uk/compo ... set__47695
Hello everyone,
I was wondering whether any of you has any experience with Rotor's direct mount 48/32 chainrings and the new ultegra/dura ace 12speed?
I'm of course planning to use the aldhu's cranks with these for the sake of compatibility but wanted to know whether the sub-compact rings had any impact on the smoothness of the front derailleur.
Thanks
Thanks
Anyone else find it interesting that we are still not seeing anyone on 12-speed shimano in the world tour?
Specialized Tarmac SL7 10r 61cm (Raw Black Carbon) / r9170 Dura-Ace Di2 11sp / Lightbicycle AR46
Cannondale SuperSlice Hi-Mod 58cm (From EF) / r8050 Ultegra Di2 11sp / AeroCoach Ascalon Carbon / AeroCoach AEOX Zephyr
It's probably 75% of Shimano riders on male teams using 12 speed Shimano.. Dont get fooled by all the 11sp cranksets. Only the full Shimano sponsor teams had crankset priority
Ah, that makes sense.
- ultimobici
- in the industry
- Contact:
Why? It won’t work.xadubo33 wrote:Hello,
Among you thereis no one who installed an front 9250 derailleur on group 9150 using the adapter that allows to connect a cable EW-SD50 on cable EW-AD305.
You can't mix old 11 speed and new 12 speed groupsets.xadubo33 wrote: ↑Sun Jun 12, 2022 8:48 pmHello,
Do you happen to know are the 12spd sprint shifters also not compatible with R8000/R9100 shifters with that adapter? The old ones are too bulky.milanv wrote: ↑Mon Jun 13, 2022 12:02 pmYou can't mix old 11 speed and new 12 speed groupsets.xadubo33 wrote: ↑Sun Jun 12, 2022 8:48 pmHello,
Pour les manettes et le der ar je suis d'accord car il gère les réglages du groupe. Mais j'ai du mal à comprendre pourquoi le der av ne pourrai pas fonctionner, hormis le fait qu' il n'est pas la même connectique. Ce que adaptateur résolve
For the controllers and the der ar I agree because it manages the group settings. But I have trouble understanding why the last av won’t work, except that it’s not the same connection. What adapter solves
eTube app, forgetting micro adjustment setting on the Front Derailleur?
Hey all, anyone notice that when you connect your bike to eTube and go to "Maintenance section" that the rear derailleur will show the Micro adjustment setting "previously" applied but the Front derailleur will be 0?
Its not a big issue, because the setting is applied to the system, however the app is either not reading it back once you set it or it forgets..
Seems like a software bug they may want to address
