Next generation of Dura-Ace Di2
OnTheRivet
by OnTheRivet
FWIW, I'm running SRAM Red DUB crankarms with a Quarq DZero power meter on a Dura Ace 9070 drivetrain and it works great.
wheelsONfire
by wheelsONfire
satanas wrote:
Tue Sep 28, 2021 9:35 am
wheelsONfire wrote:
Mon Sep 27, 2021 1:08 pm
I ordered a custom made spider for Easton EC90SL crank. This made chainline 46-47mm. No chain is thrown off now.
Can you tell us where this spider came from please? Thanks! :thumbup:
https://binghambuiltbikes.com/store/pro ... om-spider/
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
gorkypl
by gorkypl
rollinslow wrote:
Sun Sep 26, 2021 11:33 am
New DA9200 moved it out 1mm (44.5mm from 43.5mm). Campy is the issue here with design. H11 crank was 44.5mm but 12s cranks are 43.5mm. On Shimano you could use a few shims but with Campy the hirth joint and BB assembly prevents you from the option.
12s Campagnolo cranks are 44.5mm too, and 13s 1x is 45.5mm.
Cinelli Superstar Disc - Record 12s
rollinslow
by rollinslow
gorkypl wrote:
Tue Sep 28, 2021 11:54 pm
Are you sure? I'm lookking at the manual right now as I just installed a Super Record 12 crank and it say 43.5mm
Moots Vamoots RSL (2019)-Super Record 12
Cervelo S1 (2010)-Super Record 12 (viewtopic.php?f=10&t=161577)
Kestrel RT700 (2008)-Dura Ace 9000
Mosaic GT-1 (2020)-GRX Di2
gorkypl
by gorkypl
rollinslow wrote:
Wed Sep 29, 2021 1:41 am
At least this is what is stated in the technical manual on page 3:
https://www.campagnolo.com/media/files/ ... 21_ENG.pdf
rollinslow
by rollinslow
gorkypl wrote:
Wed Sep 29, 2021 9:36 am
Yeah, I must have been using an older version of the Ultra Troque tech manual from 11s generation. Thanks!
BigBoyND
by BigBoyND
ryanw wrote:
Thu Sep 23, 2021 11:48 am
What I'll be using with mine :thumbup:
After some inspiration from your post and more reading on (rare) issues with the S-works cranks, I decided to get the Quarq DZero with Red DUB arms (same as your Quarq arms). Weighs 465g including battery. Very nice! With alloy bolts (sram supplies steel) and Praxis rings, it should come in right at 605g, making it 140g lighter than the R9200-P crankset :shock:
I'll be sinning with these Red cranks on a R9200 build but oh well. Almost ordered a set of Bonti RSL 62 wheels for this Specialized build too, until I found a nice pair of lightly used i9.65 :P
Pinarello Prince 59.5cm 7.4kg frameset for sale
- R9100, P2M, HED Jet Black 6/9, Speedplay Aero SS
Canyon Speedmax Disc CF8 XL heavy
- R8000, SwissSide 62/80
Specialized Venge 58 coming soon, <6.9kg target
- R9200, Quarq, i9.65
Jonolsson
by Jonolsson
November 19
Speedman
by Speedman
Is the full groupset (Ult or DA) is available somewhere on the web ?
FIJIGabe
by FIJIGabe
Not likely, yet. Groupsets were delayed a month after OEM's started receiving their shipments, but even then, it's likely going to be a slow trickle of parts for a while.
slake21
by slake21
Speedman wrote:
Fri Oct 01, 2021 11:45 am
r2-bike: "We expect to receive it from our supplier within October (01.10.2021 - 31.10.2021)"
others don't even show any date
2019 BMC Teammachine SLR01 Disc 7kg PedalRoom
robbosmans
by robbosmans
If you want to buy it I would refresh r2 bike every hour that day, they probably won’t have a lot of it.
Jonolsson
by Jonolsson
Repeat. November 19
Thomson
by Thomson
I see the price off 9100 di2 has came down a little....
kode54
by kode54
Yeah, I noticed that as well. The 92XX is taking the crown now.
- Factor 02 VAM Disc
- Factor LS Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Moots Vamoots Disc RSL Ti
- AX Lightness VIAL evo Rim
