Dura-Ace R9200
R2-bike.com has the ULT RD now as well. Finally got it all together - let the build begin
mapaha2810 wrote: ↑Thu Dec 09, 2021 11:37 amR2-bike.com has the ULT RD now as well. Finally got it all together - let the build begin
Aaaand its gone again. 3-4 Months again.
It's crazy. Thankfully I had notifications set up for all major websites as soon as RD and FD were in stock. I'm glad I have order confirmations for both FD and RD now. Bike24 had a bit more than 10 FDs in stock on Tuesday but not longer than for a couple of hours, then all were gone. Same story with the RDs at R2 , stock didn't even last 2 hours. You need to be quick nowadays.
wondering if the new 50/34 cranksets will work with 11speed groupset, just out of curiosity..
Specialized Tarmac SL7 10r 61cm (Raw Black Carbon) / r9170 Dura-Ace Di2 11sp / Lightbicycle AR46
Cannondale SuperSlice Hi-Mod 58cm (From EF) / r8050 Ultegra Di2 11sp / AeroCoach Ascalon Carbon / AeroCoach AEOX Zephyr
Should work. the 12s chain is fine with 11s cassette and the FD probably won't be a problem after adjusting (or even without it).
No
I'm slowly starting to look for a 42T 1x12 chainring for the new DA/ULTEGRA (for hill climbing purposes). Is there anything available out there yet? Preferably an oval.
'24 S-Works Tarmac SL8 RTP - soon™
'22 Tarmac SL7 Expert | Ultegra R8100 | Alpinist CL / Custom Rapide CLX 2x60
'19 Diverge E5 Comp
'18 Epic HT Comp Carbon WMN
'18 TCR Adv Pro 1 Disc
'19 Diverge E5 Comp
They only list R9100/R8000 CX/Gravel rings in their catalogue. No mention of Shimano 12-SPD compatibility on them.
'19 Diverge E5 Comp
'19 Diverge E5 Comp
garbaruk have r8000/r9100 chainrings with '10/11/12-speed chains : including Shimano HG+'
https://www.garbaruk.com/shimano-ultegra-8000-oval.html
https://www.garbaruk.com/shimano-dura-ace-9100-oval.html
I think they're asking for rings that mount on R9200 cranksooo wrote: ↑Fri Dec 10, 2021 5:20 pmgarbaruk have r8000/r9100 chainrings with '10/11/12-speed chains : including Shimano HG+'
I'm trying to figure out the necessary wire lenghts to order. Specialized provides diagrams for the Venge but that was for R9100 and just one guideline for all sizes.
My plan is to just measure the lenths from exit-to-exit, but then how much length should I add on each of these ends? I don't want unnecessary excess flopping around inside the frame.
- FD exit to FD plug
- RD exit to RD plug
- Seat tube for seatpost mounted batteries
