BdaGhisallo
by BdaGhisallo on Tue Jan 17, 2023 11:42 am
ultimobici wrote: ↑Tue Jan 17, 2023 11:28 am
BdaGhisallo wrote: ↑Tue Jan 17, 2023 11:21 am
Can the SM-PCE01 be used to update the firmware on 12sp DI2 components with the new Y79M9801T SD300 connector cable?
Or is the SM-PCE02 the only option these days?
PCE02 only. Originally it came with SD50 connector but it has been updated recently to include SD300 connectors.
https://bettershifting.com/component/pc ... l-sm-pce1/
Thanks.
So is the PCE02 a 'should have' item for 12 sp DI2 ownership or merely a luxury 'buy it if you want it but you don't really need it' type of unit?
I have long had a PCE1 that I used for firmware updates on my 9070 and 9150 components but never needed it for any emergency remedial work. I am going to be running rim brake 9250 so the shifters will be wired in to the rest of the system.
Maxxlefty
by Maxxlefty on Tue Jan 17, 2023 4:29 pm
BdaGhisallo wrote: ↑Tue Jan 17, 2023 2:04 pm
Maxxlefty wrote: ↑Tue Jan 17, 2023 1:54 pm
Hello everybody,
I have a R9200-P powermeter.
Can you tell me how long a charge lasts?
My first charge lasted 3 months with about 70 hours of use.
How is it performing as a powermeter?
it works like the r9100-p model...
joss
by joss on Tue Jan 17, 2023 4:44 pm
How long should the Di2 cables from the front and rear derailleur to the battery in the seatpost be?
415mm chainstay, 550 seat tube....
George46GR
by George46GR on Thu Jan 19, 2023 9:12 am
Good morning, what is the expected lifespan (in km) of a 12 sp Shimano XTR (CN-M910) chain supposed it is cleared and lubed as necessary ? Thank you !
2023 Cervelo S5, size 56, sapphire/ice
Tifosiphil
by Tifosiphil on Fri Jan 20, 2023 3:19 pm
Random question incoming so apologies.
I was running DI2 with an internal battery but had an external battery and mount to hand so stuck that on a new build. I've now seen the crazy prices BTR2's are going for and probably shouldn't keep 3 for spare in my toolbox.
To check they still work what is the minimum requirement to charge them, can I simply plug them into a spare junction A I have and connect it up or does it need to be part of a full system?
sealucky
by sealucky on Sun Jan 22, 2023 9:44 pm
Maxxlefty wrote: ↑Tue Jan 17, 2023 4:29 pm
Hello everybody,
bad news..because 9100 pm is rubbish
