Shiv di2 wiring
miltmaster3
by miltmaster3
I just see the new pdf for di2 wiring I nave a 2016 shiv model and I need to go to di2 update ! In the photo you can see the RS 920e put in the frame ! Do I have to drill my frame ? Any help welcome Image
πατα τραβα ρε
rainerhq
by rainerhq
I think its better to go this route:
Domane
Speed Concept
"Nothing compares to the simple pleasure of a bike ride"
miltmaster3
by miltmaster3
rainerhq wrote:I think its better to go this route:
You mean this routing
πατα τραβα ρε
rainerhq
by rainerhq
Routing can vary, but I mean you can´t drill 20mm hole in your frame.
Domane
Speed Concept
miltmaster3
by miltmaster3
rainerhq wrote:Routing can vary, but I mean you can´t drill 20mm hole in your frame.
Thanks for your answer! Do you know how many drill I have to make ?
πατα τραβα ρε
FIJIGabe
by FIJIGabe
None. The point of the second diagram is to show that you don't need to drill your frame. All of those Junction B's should just drop stright into the frame, no drilling required.
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
Madone 5, Cobia. I own a lot of Treks.
miltmaster3
by miltmaster3
Ew90b how the cables came out ? Drill the seat post ? And how do I get access to frame to put jc41 ? I know that I have canals for derailleur! Any help is welcome
πατα τραβα ρε
rainerhq
by rainerhq
With my Trek Speed Concept I had to drill the seatpost.
I use only one JC41, which drops straight into the seattube.
Domane
Speed Concept
miltmaster3
by miltmaster3
Thanks my friend
πατα τραβα ρε
miltmaster3
by miltmaster3
How to put the wire there ?
πατα τραβα ρε
ParisCarbon
by ParisCarbon
I did the di2 mod to my 2016.. its pretty easy really... I did alot of googling of Tinkoff Shiv TT bikes, and Tony Martins bikes to get ideas...
In the end, we drilled a hole in the top of the seatpost, my EW90 is sitting at the back of the seat out of site with velcro.. If I want to charge, I just pull it off the velco and insert charger to port...
Battery is in the post with the shiv seatpost battery kit (needed to purchase seperately since bike is non Di2)
Cable guides for F/R mechs need to be removed... I just tugged on them hard and they broke free...
Next you need to cut an opening in the face of the upper headtube behind where the stem will fit to allow all the wiring in there from the front end..
I also needed to cut away some of the back of the stem to make room for the wires to run into the frame, and I cut two small openings to allow the bar end shifter wires in to the stem..
The brake lever/shifter wires all run internally within the basebar, and pop out in the middle of the stem.. those di2 shifter wires run into an ew90 in the hole you cut in the frame.. (best thing to do is feed the wires in and work from the bottom of the headtube, with the fork out there a PILE of room in there, its all open) The bar end shifters, I am using the ski bends, so I run the cables internally from the shifter end to the insertion point of the mount on the risers, notched a small hole in aerobar and popped the di2 cable out the bottom.. I then run those cables down the risers (just electric taped) then those cables on each side run into the 2 small holes cut on the side of the stem and through the back into the hole and into another ew90... those are all chained together then to another ew90 in the BB area which is also connected to the f/r mechs... yeah it sounds like alot, but its not "that bad" my front end is disassembled to a point right now (aerobars off) I'll get some pics tonite and post what I did to mine.... just remember to wrap all those ew90s in foam wrap or something... when you hit bumps in the road its annoying as %%%% when they ping off the carbon....
miltmaster3
by miltmaster3
Thank you so much you make my day
πατα τραβα ρε
ParisCarbon
by ParisCarbon
miltmaster3 wrote:
Tue Mar 26, 2019 1:58 pm
No prob.. the other thing with mine is I left the rear brake cable with the default routing.. so leave that hard cable guide alone unless you want to internally route the rear cable as well trhough the back of the stem... I just looked at as its going to be a major PITA if I need to change a rear brake cable and housing to dig in there.... its doable for sure and cleaner, but in my opinion, wasn' t worth the headache when new cable is required..
ParisCarbon
by ParisCarbon
ParisCarbon wrote:
Tue Mar 26, 2019 1:52 pm
The brake lever/shifter wires all run internally within the basebar, and pop out in the middle of the stem.. those di2 shifter wires run into an ew90 in the hole you cut in the frame.. (best thing to do is feed the wires in and work from the bottom of the headtube, with the fork out there a PILE of room in there, its all open) The bar end shifters, I am using the ski bends, so I run the cables internally from the shifter end to the insertion point of the mount on the risers, notched a small hole in aerobar and popped the di2 cable out the bottom.. I then run those cables down the risers (just electric taped) then those cables on each side run into the 2 small holes cut on the side of the stem and through the back into the hole and into another jc41... those are all chained together then to another jc41 in the BB area which is also connected to the f/r mechs... yeah it sounds like alot, but its not "that bad" my front end is disassembled to a point right now (aerobars off) I'll get some pics tonite and post what I did to mine.... just remember to wrap all those jc41s in foam wrap or something... when you hit bumps in the road its annoying as %%%% when they ping off the carbon....
miltmaster3
by miltmaster3
Some parts has arrived
πατα τραβα ρε
