New Rim Brakes: DA9100 or Sram Axs
Hello
Looking for a set of new Rim Brakes on my old Sram Red 10 Groupset
I think the first gen of sram brakes isn,t the best choice
I think the DA 9100 Series is a great choice,but now i see Sram had a new Rim brake on the market with the Axs group
Can anyone help me with my decision?
Thanks
Thanks
- Moderator
- Contact:
EE
Sent from my SM-G975F using Tapatalk
Using Tapatalk
Have you tried to service your brakes and get some new pads? That can make them work a lot better.Pinguin wrote: ↑Wed Mar 20, 2019 5:57 pmHello
Thanks
Sram isn't famous for having the best braking performance but it's certainly not bad.
What rim material and pads do you use?
Never service to my old brakes,i dont know how to servicealcatraz wrote: ↑Thu Mar 21, 2019 12:04 pmHave you tried to service your brakes and get some new pads? That can make them work a lot better.Pinguin wrote: ↑Wed Mar 20, 2019 5:57 pmHello
Thanks
Rims are carbon and alu
Wipe your alloy brake tracks down with some alcohol, put some swissstop black or coolstop pads on, and last check that your calipers don't have play in its linkages by grabbing the arms at the ends and pulling/pushing. If you notice excessive play it needs to be eliminated by localizing where its created and tighten down those joints. If the calipers are dirty better clean and grease so they don't seize.
I'm running 28mm GP5000TL's with my 9000 brakes right now. Everything fits just fine.
GP5000 28 mm are actually 28mm on most wheels.
GP4000 - not so much. I think Shimano increased the clearance at the brake between generations so they could say they coped with all "28mm" tyres, but I'm not 100% sure.
- wheelsONfire
If weight isn't an issue, you could also check TRP brakes
https://trpcycling.com/shop/category/road/
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
Ex bike; Vial EVO D
- Similar Topics
- Replies
- Views
- Last post
- 11 Replies
- 806 Views
Last post by shuttlenote
Wed Jul 17, 2019 10:36 pm
- 1 Replies
- 511 Views
Last post by Jugi
Wed Mar 06, 2019 7:21 pm
- 3 Replies
- 310 Views
Last post by RocketRacing
Sat Nov 09, 2019 2:20 am
- 9 Replies
- 1034 Views
Last post by CEVelo
Wed Feb 20, 2019 7:22 am
Sram Force or Ultegra 11 speed mechanical shifters with hydro flat brakes.
by Juanmoretime » Wed Jul 03, 2019 10:59 am » in Road - 4 Replies
- 391 Views
Last post by ooo
Thu Jul 04, 2019 3:39 pm
