Campy compact crankset question
Miller
by Miller
Those two are basically the same thing with different fixation on the spindle. I haven't tried PT2 but if it works as it's meant to it should be easy to install and uninstall. I have the Potenza UT chainset. It is very easy to work with and gives no hassle. The only real negative I'd put against it is that after a year of use the black finish on the crank is wearing where my shoe brushes against it. I can live with that.
Last year after many years on 175 I tried a 172.5 chainset cos it was a deal. Conclusion: I didn't notice any difference from 175.
morrisond
by morrisond
Get the Ultra Torque - it's a great system and all you need is an 10mm Allen Key Socket to install - Super Easy and IMO best crank/BB system out there.
Roel W
by Roel W
I ordered the new Potenza Ultra-Torque 175mm cranckset online. Delivery was today and I found it was a HO version although the website stated it as regular cranckset. The HO version is a hydraulic disc brake optimized version with the chainrings positioned 2.5mm further outboard of a bike’s centerline than is found on a rim-brake bike (according to Cyclingtips). My bike is rim-brake.
Is this something to worry about or should I continue installing it?
I found out most websites have HO versions in stock but regular 175mm 50-34 black versions are hard to find at an affordable price.
CANYON Ultimate AL 2010
CANYON Ultimate CF SL 2014
CANYON Ultimate CF SL disc 2018
Instagram @roeleur
Miller
by Miller
This is really not worth worrying about.
