Campy compact crankset question
ylwgto
by ylwgto
I am looking for advice on crankset options for a bike I am taking to the Apls in July this year. I'm a larger rider (195lb) and won't pretend I'm strong enough to push the gears I currently have on my bike (53/39, 177.5mm cranks and 12-25 cassette) on these climbs.
I'm running pre-2015 Campy SR11. I'll be changing the cassette to 12-29. Changing the crankset has been a bit more complicated as standard crank ring BCD (135mm) is different than compact BCD (110 with 112mm weird bolt). So a ring swap is not possible. Other Campy compact (50/34) cranksets are $$$ in the new or used market. I'm looking into the Potenza group crankset (50/34, 175mm) as an option, but am not in love with the 4 arm look and prefer the Ultra Torque design (plus they are a bit hefty).
Any other suggestions?
Will the Campy 10 speed era cranks work with an 11s drivetrain or are the rings spaced differently?
Other brands that work well with Campy 11?
BTW, my FD is a chorus standard + compact compatible unit.
Thanks!!!
kervelo
by kervelo
ylwgto wrote:
Mon Mar 18, 2019 6:52 pm
The Campagnolo 10sp cranks work fine with 11sp drivetrain. I used similar configuration with my 11sp Chorus for years without any issues.
Nejmann
by Nejmann
Is it a just for riding in the alps with friends or an event linke Gran Fondo La Marmotte?
I’m 215 lbs and did the La Marmotte - 165 km going over Glandon, telegraphe, Galibier and alp d huez in one day and that was one 50/34 and 11-28. So if it’s just ridning in the alps with friends 53/39 - 11-29 is duable.
Miller
by Miller
Current Potenza chainsets are ultratorque. They might not be the lightest but they're well made.
AJS914
by AJS914
Just make sure to not buy the older and cheaper Power Torque model.
Here's one for $150. Seems inexpensive enough to me for a Campy crankset.
https://www.ebay.com/itm/New-Campagnolo ... 2884936167
c60rider
by c60rider
If you don't like the 4 arm design of potenza what about sourcing an Athena 5 arm version. They did them in Carbon and black alloy if you want it to match the black of SR. The only negative is it's power torque so you need a bearing puller to get it off.
Miller
by Miller
The older and cheaper Potenza chainset was PT2 with built-in crank extractor.
The Athena carbon chainset was first gen PT that people moaned about however it was surprisingly light. Difficult to find now I should think.
robertbb
by robertbb
Have a look at planet cyclery online. They have all different Campy cranksets, current and NOS, and you might find what you are looking for.
Just in January I found an 5-arm Athena carbon Ultra Torque crank with the larger BCD (for standard chainrings), in 172.5mm. Bought it specifically for a 1x project I'm putting together with a NW chainring that will fit on that BCD.
Catagory6
by Catagory6
this auction will probably go WAY too high
https://www.ebay.com/itm/Campagnolo-Rec ... Sw9P1ciVe3
i've scored some AMAZING deals, just keeping a very close watch on this link for "bin" auctions
https://www.ebay.com/b/Cranksets/109118 ... _PrefLoc=3
they pop up every once in a while. don't overlook centaur/veloce, or square taper
Catagory6
by Catagory6
double post
Miller
by Miller
Catagory6 wrote:
Tue Mar 19, 2019 2:43 am
Wow, a Record CT square taper carbon chainset - that is class. That was released not long after Shimano had gone to two-part chainsets and were pushing these as being 'stiffer'. The idea of crank stiffness was something that had never occurred to me, in those long-gone innocent days, but then I got a s/h copy of a Record CT carbon chainset, and it did feel stiffer than anything I'd used before. Which was a surprise. Lovely chainset. But I sold it and went to UT only a year or two later. The Campag square taper carbon chainsets were only briefly in their catalogue, they introduced UT across the range very quickly.
I know nobody uses three-part chainsets any more but the Campag square taper chainsets with the hollow-axle 102mm cartridge BBs were nicely engineered and easy to work with.
kytyree
by kytyree
They were beauties too...
AJS914
by AJS914
Those bottom brackets were also smooth, well sealed, and lasted for years and years without service.
kervelo
by kervelo
Wiggle currently has the Campagnolo Record 11sp crankset with 52/36 for 250 GBP. Unfortunately the price seems to be valid for UK customers only.
Roel W
by Roel W
So this is Power Torque +:
https://hollandbikeshop.com/campagnolo/ ... alu-zwart/
Recommended or not? I want to get rid of my Athena Power Torque 2014 chainset as the rings are worn out and I don't want to buy the expensive tools (Canyon Service Center agreed to remove the chainset). Doing my own maintenance without expensive tools is important for me.
Or should I buy this Potenza 2018 Ultra Torque?
https://www.mantel.com/be/campagnolo-po ... Ijc3RhcnQ1
Are the Centaur 11-speed chainsets recommended?
I'm in doubt about 172,5mm or 175mm too. My older Canyon bikes have 172,5, the latest Canyon bikes have 175mm (all bikes are size L, compact 50/34 chainset).
CANYON Ultimate AL 2010
CANYON Ultimate CF SL 2014
CANYON Ultimate CF SL disc 2018
Instagram @roeleur
