Rings option for sram red 22
ninjanoir78
by ninjanoir78
Hi,,,
On my red 22, I have 52/36 and I'm looking for 50t, i need the model with hidden bolt, do you know some other brands instead of sram?
Thanks
Envoyé de mon SM-A530W en utilisant Tapatalk
Ninja
grover
by grover
Praxis Works
ninjanoir78
by ninjanoir78
grover wrote:Praxis Works
I wonder if they have the 50 only, dont need the small one
Ninja
Ritxis
by Ritxis
ninjanoir78 wrote:
Thu Mar 14, 2019 6:40 pm
Hi,,,
Thanks
Miche, Specialites TA, Stronglight.................I am placed Miche in a Red BB30 and Stronglight ct2 in a Red GXP
wheelsONfire
by wheelsONfire
Why not Srams chainring? I ride 50/36 combo.
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
ninjanoir78
by ninjanoir78
wheelsONfire wrote:Why not Srams chainring? I ride 50/36 combo.
Do you have the black 50t ring? Or the previous version, thicker plate, grey/black?
Ninja
snaxez
by snaxez
I ride rotor q-rings on my sram red22, but not sure if it would work if you only swap the large one. They have regular round rings as well. Lighter, than red22 rings.
wheelsONfire
by wheelsONfire
ninjanoir78 wrote:
Sun Mar 17, 2019 12:32 pm
Yes, it's black. I ordered 50/34, BB386 version + a separate 36T chainring.
Not really a light set though, 648 grams.
It's the hidden bolt version with exchangeable spider
Bikes:
Ex bike; Vial EVO D
RTSM
by RTSM
Hello Ninja, I just swapped out my stock SRAM Red 22 rings for the AbsoluteBlack 50/34 rings. They mount using the stock SRAM bolts and am happy that they shift great (after tweaking the front derailleur set up).
This is my first time using oval rings and definetly like the improvement in my cadence and efficiency. They weigh about 8 grams heavier than my stock SRAM Red rings however the marginal weight is well worth the efficiency I am getting, definetly recomend the AbsoulteBlack oval rings and btw, they look sharp.
ninjanoir78
by ninjanoir78
RTSM wrote:Hello Ninja, I just swapped out my stock SRAM Red 22 rings for the AbsoluteBlack 50/34 rings. They mount using the stock SRAM bolts and am happy that they shift great (after tweaking the front derailleur set up).
I've tried absolute black on my hologram crankset but I had some problems with Fd etap
Ninja
snaxez
by snaxez
If you have Etap, then I would go with Rotor NoQ rings. Oval ones are hard to get working perfect with etap.
moyboy
by moyboy
Praxis give you the option of hidden or non hidden... they are built well and allow for great shifting with etap / di2
