DM Crankset and Power
MechMitch
by MechMitch
hey,
So im gonna get a new power meter and was looking into getting DM as i want to swap between 2x and 1x. I have two optiions so far
Rotor InPower
Easton Cinch- This is lighter then the rotor but doesnt have oval rings, although i can easilty swap tem out for the same price
Any thoughts? Theese are very similar prices
is there any similar options for price and also dual?
AZR3
by AZR3
I was looking into the cinch but had a hard time finding any actual owner reviews and the few users I did find weren’t too impressed by it. Some where having lots of spikes/drop outs and others were having battery issues. Granted those were only a few people but I couldn’t find much else so I opted for a quarq as it was cheaper than a 2inpower and I don’t mind switching rings to save $500
onemanpeloton
by onemanpeloton
praxis zayante, they do this chainset with a 4iii PM but only single sided
2017 Giant TCR Disc
2015 Giant TCX
2016 Cube Stereo 140
dcorn
by dcorn
Is DM direct mount? Check out Power2Max. Their PM for rotor cranks is cheaper than the Inpower.
jfranci3
by jfranci3
I wouldn't plan swapping out a spider PM too often. The hardware won't hold up. I also wouldn't plan on changing rings too often as chainring bolts and spider lockrings do not have that durabilty. The spindle PMs don't have the accuracy levels of the other solutions. I'd just go crank arm.
Edit: going 1x to 2x on the same bike doesn't make any sense. I can see changing gearing on 1x, but not 1x to 2x.
AZR3
by AZR3
So are you just changing between 1x and 2x, using the same crank? If so then perhaps look at pedal power meters, I have Assioma DUOs and love them. I only added a quarq to my gravel bike because of the possibility of having to hike-a-bike some sections of some rides so had to get mtb shoes which forced a pedal change. If your staying on road is just go with power meter pedals and be done with it
kafreeman
by kafreeman
Power2Max on an easton or rotor aldhu crank.
Sent from my SM-G965U using Tapatalk
MechMitch
by MechMitch
i wouldnt be swapping out the pm spider, because its dm so the pm is either on the crank like imnpower or in the spindle like easton cinch.
i ride restrcited gearing and racing goes up some really steep hills so i need the 2x option for road racing. 1x for crits and timetrials.
I am looking into p2m, but was hoping on something that is direct mount on the crank or in the spindle.
Ill have a look at praxis later
kafreeman
by kafreeman
Yeah it's a spider based power meter so you would have to swap chainrings.
Rotor has the 2 in power that is direct mount but I only see a 30 mm spindle.
The in power is a single side power output since it measuring the strain of the spindle.
MechMitch
by MechMitch
kafreeman wrote:
Thu Mar 14, 2019 3:48 am
For the P2M yes you are correct. but the inpower and cinch it would be chainrings, so not moving the power meter
kafreeman
by kafreeman
Pedal based option might be the best bet. I went P2max on a gravel bike, otherwise would have gone with the Assiomas.
If switching chain rings for climbing vs tt/ crit are pedals staying the same?
MechMitch
by MechMitch
kafreeman wrote:
Thu Mar 14, 2019 4:18 am
Thanks for the advice. yup pedals stay the same for everything
