DaveS
by DaveS on Tue Feb 04, 2020 7:05 pm
Alexbn921 wrote: ↑Tue Feb 04, 2020 6:15 pm
Campy cassette spacing is different than Sram. Front handles a 15 tooth jump with plenty of clearance. I have a custom 33/48 setup.
The spacing is slightly different, but we do have reports of one user who put a SRAM 12 cassette on his Campy 12 EPS equipped bike, with a Campy chain and had no problem with it, so the difference is small.
There's also a report of the full length measurement of both cassettes. They are not identical, but closer than 11 speed cassettes, that most people claim can be used interchangeably.
viewtopic.php?f=3&t=158450&hilit=campy+ ... patibility
Alexbn921
by Alexbn921 on Tue Feb 04, 2020 8:39 pm
DaveS wrote: ↑Tue Feb 04, 2020 7:05 pm
I agree with Calnago on this. The small differences are bigger than most realize and will cause long term problems. I highly advise against it. At the same time I've done my share of mixing and matching.
Good enough is the enemy of great.
edit
Sram shifting with Campy everything else would be much more advisable than using an AXS chain on Campy cassette or vis versa. The chain to teeth interface is critical.
Ride fast Take chances
DaveS
by DaveS on Tue Feb 04, 2020 9:24 pm
Only time will tell if the mismatch of chains and sprockets creates a problem. I used AXS chainsy for 400 miles on each of my Campy 12 bikes. No problem, when I switched back to Campy 12 chain. I have 4 Campy chains and 2 AXS chains in rotation on two bikes. Whenever I remove a chain for cleaning, a different chains goes on the bike.
Too bad that SRAM can't really explain the switch to a #41 chain.
kroem
jlok
by jlok on Thu Mar 19, 2020 8:33 am
Anyone tried Carbon-Ti AXS 50 / 35 combination?
kroem
by kroem on Thu Mar 19, 2020 9:01 am
Fyi. Stone has a spider for direct mount om AXS cranks, to 110bcd. Ive order one and can report...
kroem on Thu Mar 19, 2020 1:35 pm, edited 1 time in total.
Jasco
by Jasco on Thu Mar 19, 2020 12:45 pm
kroem wrote:Fyi. Stone has a spider for direct mount om AXS cranks, to 1110bcd. Ive order one and can report...
I’ve not heard of Stone. Could you post a link?
kroem
andy4g63
by andy4g63 on Thu Mar 19, 2020 7:30 pm
Rotor makes 4 bolt rings, in round and oval with 110 BCD.
They are specifically made for Sram AXS .
The come on48/35 only and fit Shimano 4 bolt, and Rotor's Alhdu, Vegast and some more from their lineup.
Andy13
by Andy13 on Fri May 29, 2020 10:28 pm
Are you saying the sram axs front derailleur will handle a 15 tooth jump? or more? since you say plenty of clearance. I seem to remember someone saying they got Rotor oval chainrings with a 13 tooth difference to work which would lead me to believe round chainrings could handle a bigger difference. TIA.
