ritchey wcs carbon one bolt seatpost
blue151
by blue151
Hi,
Has anyone used the ritchey wcs one bolt carbon seatpost, or similar post in their range (with the 7x9.6 clamp kit) with any saddles with 7x9 rails?
I have a mcfk saddle but was unsure what seatpost to use with it - I don't really want to spend the money on a super light seatpost.
I was after a post with 20-25mm setback in 31.6mm. Happy to hear other peoples recommendations that won't break the bank.
joejack951
by joejack951
I have the Superlogic one-bolt post on my HongFu FM079-F build with a Fizik Arione R1 saddle (7x9mm rails).
Anything in particular you want to know about it? Zero slipping or squeaking issues so far, though, I have to admit my mileage isn't anything to brag about. It all went together nicely and the cost wasn't outrageous compared to some options.
Alexandrumarian
by Alexandrumarian
Superlogic here too, no problem at over 90Kg. Used with Fizik and Selle San Marco ovals. For 7x9 I had to purchase ears separately and it is a rather complicated process figuring out the exact item number. Also if you switch saddles often, the clamping system can be a bit fiddly but you get the hang of it eventually.
eric01
by eric01
Also a superlogic with fizik antares 00 carbon rails. Works great.
wheelbuilder
by wheelbuilder
I have three of the wcs versions. Light, comfortable, look great, long lasting, and the best one-bolt clamping system available anywhere imo.
blue151
by blue151
Thanks for the replies.
I thought Fizik rails were 7x9.6? i wonder wheterht he 0.6mm differential will make a difference. I am just weary that it may place undue pressue on the rails
maxxevv
by maxxevv
The clamps aren't exactly good with carbon rails. It left bite marks on my Prologo and Selle Italia saddles even though I had specifically fitted on the correctly spec'd clamps.
RyanH
by RyanH
I was using it just fine with the same saddle.
Strava
Not for the sensitive types. My Instagram reviews
The Ex's: I've lost track...
robertbb
by robertbb
I use the WCS Carbon 1 bolt (zero offset 27.2), on two bikes, both with Specialized Romin Evo Pro with the carbon 7/9.6 rails.
As has been said, it is the best one bolt clamping system there is. Never had an issue at all.
The post is sublimely comfortable.
Now if there was a Ti bolt to replace the steel one, I'd be on it like a phat kid on pie.
Alexandrumarian
by Alexandrumarian
robertbb wrote:
Tue Mar 12, 2019 6:00 am
Torontocycles, m6x55 should fit. 5$ for 7 grams, not too bad :)
Last edited by Alexandrumarian on Tue Mar 12, 2019 9:26 am, edited 1 time in total.
Zakalwe
by Zakalwe
Superlogic with an SLR Kit Carbonio, precisely 0 issues. One of the best posts and clamp systems out there
NiFTY
by NiFTY
Have run 2 superligic w 7x9.6 with s works toupe. Now 8x8.5 w ax lightness leaf.
robertbb
by robertbb
Alexandrumarian wrote:
Tue Mar 12, 2019 8:41 am
THANK YOU! I'm on it! The stock Ritchey one is starting to rust inside the head on both bikes....
blue151
by blue151
NiFTY wrote:
Tue Mar 12, 2019 8:52 am
Hi Nifty, Did you have to change clamps to do this?
blue151
by blue151
Zakalwe wrote:
Tue Mar 12, 2019 8:48 am
Hi Zakalwe, do you know if the SLR Carbonio has 7x9 or 7x9.6 rails? I had a quick google and it seems to depend on the which year the saddle was from?
