Heavy Sram RED Shifter
Darmen
by Darmen
Hi
i wondering why my red shifter 22 c2 weight 302g.
Its 20g more than claimed weight :(
hereis some photo of the weight
any suggestion what's gone wrong?
Beaver
by Beaver
I only have older sets - these are all quite close to the stated weight. Same for the front and derailleurs.
Maybe someone else has put a newer set on a set of scales?
jeanjacques
by jeanjacques
I've seen that too on other posts, the weird thing is the Rival shifter tend to go lighter, 325g on this post: viewtopic.php?f=10&t=154636
Darmen
by Darmen
Beaver wrote:
Fri Mar 08, 2019 9:54 am
Wow thanks, can you weight the clamp and the hood?
Darmen
by Darmen
jeanjacques wrote:
Fri Mar 08, 2019 11:49 am
Wow thats light for rival shifter.
I feel cheated with my red shifter, its almost same as force shifter at half price
alcatraz
by alcatraz
My force 10s shifters are 327gr
My red 10s shifters are 285-290gr (i forgot).
Beaver
by Beaver
Sorry, the hoods I don't want to possibly damage - but I have a spare set from 2017, a tad lighter than yours.
The clamps seem to be the same.
Darmen
by Darmen
alcatraz wrote:
Sat Mar 09, 2019 4:21 pm
from bike rumor force 11s 317gr. 10 more than claimed
Darmen
by Darmen
Beaver wrote:
Sat Mar 09, 2019 4:25 pm
thanks a lot, 5 g from hood and clamp
i'm beginning to suspect that the seller used force body red lever, is that possible?
Marin
by Marin
AFAIK the bodies are the same across all shifters?
Darmen
by Darmen
Marin wrote:
Mon Mar 11, 2019 9:31 am
dudemanppl wrote:
Mon Aug 14, 2017 2:43 am
Force also uses a heavier shifter body. Exact same internals.
viewtopic.php?t=146941
dudemanppl said Force uses a heavier shifter body. Exact same internals.
jeanjacques
by jeanjacques
The body seem identical, only difference is alloy speed lever on Force and some ti screw on Red. As the last poste said (thread above), maybe the brake lever on Force is composit and carbon on Red. We look at less than 10g difference, so it can't have big difference.
alcatraz
by alcatraz
Red has different shifter body, clamp, shift lever. What else?
Lighter hoods?
SQUICCHI
by SQUICCHI
I use the Sram Force shifter, I need to check how heavy they are!
dudemanppl
by dudemanppl
Clamps are the same between both, only the shift lever and body are different.
