Let's talk rotors
bruno2000
by bruno2000
I'm also doubting in buying the new Dura-ace or the new XTR Rotors.
As for esthetics I like the XTR more.
But on a technical level would the Dura-Ace rotor not been made to dissipate heat better?
I can imagine heat being a biggen problem on a road bike than on a mtb bike.
by Nefarious86
If you can cook a 160/140mm XTR rotor combo on the road then the DA rotor won't be what saves you...
Sent from my SM-G975F using Tapatalk
Using Tapatalk
TheRich
by TheRich
bruno2000 wrote:
Fri Apr 05, 2019 11:05 am
I have no doubt that the newest rotors are better, but it's probably less of a difference than between standard non-finned ice tech rotors and the old XTR RT99 rotors.
Mountain bikes that need big rotors generate more heat because the slopes are steeper and the turns are closer together. The road equivalent would be racing down Lombard St in San Francisco. Plus it seems like road levers give more leverage than MTB levers. Maybe it's the same piston and a longer lever, but road brakes are more powerful than they look when compared to MTB brakes.
scale29
by scale29
Noctiluxx wrote:
Thu Apr 04, 2019 8:13 pm
Has anyone used the Hope Floating disk rotors on their Ultegra brakes?
Yes, they won’t work without a bit of tinkering, the rivets contact with the calliper.
bilwit
by bilwit
Yeti wrote:
Thu Apr 04, 2019 6:03 pm
So what is the general consensus on "the best" rotor to use with Shimano hydraulics? The Dura Ace RT900 or the XTR MT900? Also, at 155 lbs do I really need a 160mm rotor on the front. I know how to brake and don't drag my brakes on extended downhills. Overkill with 160mm?
I used the RT900s when they came out and just recently swapped them for the new MT900s on my road bike and I don't see any reason to use the RT900s.. they look terrible and they're heavier. I'm 135lbs and use 160mm/140mm just because it seems standard. Also feels like the 160 on the front evens out the break feel to me.
spdntrxi
by spdntrxi
bilwit wrote:
Fri Apr 05, 2019 6:28 pm
MT900 in 140 are not really good looking to me either ( 4arm)... are the 160mm's 5 arm atleast ?) most pics I see are the 5 arm 180's which look great.
bilwit
by bilwit
spdntrxi wrote:
Fri Apr 05, 2019 6:53 pm
160s are 4-arm too. I had reservations about those 90 degree arms but it's a better look to my eye than the obnoxious ice fins on the road model
spdntrxi
by spdntrxi
Thanks for confirming... that was my concern. Slight bummer
ichobi
by ichobi
Anyone got experience with the Carbon-Ti rotor? They seems to be half the weight of SRAM Centerline XR rotor.
http://www.carbon-ti.com/products/brake ... rbon-2-160
160mm rotor at only 77g. Quite costly though.
ChiZ01
by ChiZ01
ichobi wrote:
Mon Apr 08, 2019 5:05 pm
77g + 30g centerlock adapter is not really light
bruno2000
by bruno2000
On Cyclingtips I saw a pictyure of Sagan riding 160mm front xtr rotor and 140mm rear xtr rotor.
ryanw
by ryanw
I think they look better than the DA 9100 rotors, and they weigh 22g less combined (160/140mm):
Allez Sprint Disc - 7.60kg
SL7 S-Works - 6.73kg
www.rhinosworkshop.co.uk
IG: RhinosWorkshop
willmac
by willmac
Do you have a photo of the rear rotor?
ryanw
by ryanw
It's identical but smaller.
IG: RhinosWorkshop
willmac
by willmac
ryanw wrote:
Wed Apr 10, 2019 4:56 pm
I assumed that. I was wondering about the aesthetics and the ratio of actual rotor vs spider compared to the larger 160.
