What Equipment Not to Buy
L3X
by L3X
RTW wrote:
Tue Mar 05, 2019 1:21 pm
I'm not having a go at you. I just used to be very similar, but then opened up a bit and enjoyed things a bit more.
Just think it's cool that you have a totally different view and approach on things, each their own I guess - that's why I specifically said 'in my opinion'. On #1, this obviously is a bike forum, not a stove forum so that was pointed specifically at bikes :P
ParisCarbon
by ParisCarbon
robertbb wrote:
Tue Mar 05, 2019 7:14 am
So you're saying Di2 not as great as you thought?
Anyway, my 2c for equipment not to buy: any wheel with fat aluminium spokes, including Shamals. Just say no.
It was my first stab at electronics... It was great when it worked properly.. but I had multiple instances of the chain dropping from the 53 to the 39 ring if I hit a bump, once during the restart of a race, it just ghost shifted from the 53 to the 39 without me touching a thing... as I watched everyone sprint away... multiple instances of not being able to get it to the 11 cog, but put it on the workstand and it was solid.. I just gave up on it..
We drilled up my Shiv TT for Di2 and its been flawless.. Id go Campy on it as well, but the DTI for the Campy wouldnt allow me internal routing..
tabl10s
by tabl10s
Valbrona wrote:
Sun Mar 03, 2019 6:39 pm
After messing around with bikes for 40 years, my advice on what NOT to buy:-
1/ Anything Campagnolo. Too many year-on-year compatability issues.
2/ Campagnolo cranksets. Extra/expensive tooling required to replace bearings.
3/ Novatec hubs. Lack of end user infromation makes swapping freehub bodies a faff if you do not know if end caps need switching or washers need relocating.
Anything else?
Tune could also be in the mix:
https://youtu.be/l8qsvupxxTg
https://youtu.be/WbZDswqwBXE
2015 Pinarello F8: 13.05lbs/5.915kg
2016 Rca: 11.07lbs/5.048kg
2018 Rca
2018 S-Works SL6 Ultralight: 12.03lbs
L3X
by L3X
Some of the older Tune hubs surely weren't great... Personally I broke the carbon axle on a prince hub. On the positive side, Tune was very helpful in getting it fixed. I have 4 or 5 sets of new Tune hubs that I use, they're all great for me so far.
icantaffordcycling
by icantaffordcycling
Staying away from specialized inner tubes. Tried a couple because I was out of tubes and all my favorite LBS stocked. expensive and 2/4 failed out of the box. Never again.
LouisN
by LouisN
Some negativity in that thread....
With a little patience, we'll eventually see just about every single bicyle part end up here.... :wink:
Louis :)
Ok...
don't ever buy s-works exos shoes. A problematic product that is ridicously overprized as anything with s-works written on it.
TonyM
by TonyM
LouisN wrote:Some negativity in that thread....
Louis :)
True!!!
And if we make the opposite thread it would most probably also end up like this one also...LOL
For me it is however interesting to see the reason given by the people why they do not recommend a specific product.
andreas
by andreas
Silca Seat Roll Premio... fiddly with the two separate tightening mechanisms, very low capacity considering the external volume, and when riding in rain the bag and contents get wet and gritty. Without doubt the worst saddle bag I've had, polished turd.
RocketRacing
by RocketRacing
prebsy wrote:
Mon Mar 04, 2019 4:02 pm
Sock3t wrote:
Sun Mar 03, 2019 11:30 pm
Don't buy a prebuilt bicycle with the idea you're going to upgrade it later.
X 1000. A lot of bikes look like good deals until you realize you will be selling the cockpit , crankset, wheels.
Not sure i agree. Depends on what you plan to upgrade to/with.
I have personally bought the best frame i can, with the cheapest components specced (in reality, i have gone used for my two exotic builds). I then swap out just about everything for top spec groupset, and exotic light carbin parts. I avoid higher end components oem, because they still do not meet my build standards, so they get swapped out anyway.
Or that is how i logic it.
These days, a new frame is only a few bucks less than the same frame and a full bike. Strip parts off as you aquire dream bike parts, sell them, and you are ahead. Then you get dream bike specs for a everyman price. Twice now i have used mint (used) near top end frames (the top tops are always silly expensive for a few more grams saving... not worth the cost per gram) upgraded to higher specs than top tear factory offerings (way lighter too), for about half the price of the oem top line offerings.
Valbrona
by Valbrona
Places you find Hirth joints:-
1/ Campagnolo cranksets.
2/ Barney Rubble's car.
robertbb
by robertbb
Valbrona wrote:
Wed Mar 06, 2019 12:37 am
:unbelievable:
Ultra Torque is an elegant and reliable solution. But haters gonna hate.
blaugrana
by blaugrana
robertbb wrote:
Wed Mar 06, 2019 12:59 am
:unbelievable:
Exactly. There are things I might dislike about Campagnolo, but the Ultra Torque cranksets work well and the joint has never given me any trouble. Also, it's easy to replace the bearings with a cheap generic 15€ bearing puller.
blaugrana
by blaugrana
Edit: double post.
kervelo
by kervelo
blaugrana wrote:
Wed Mar 06, 2019 1:31 am
:unbelievable:
Absolutely true. If you have issues with those, you must be doing something wrong.
