30mm Tubeless
Campervan
by Campervan
Hi, I am looking for some comfy, yet fast tubeless tyres. I previously have used 25 Schwalbe pro one at 70psi. My Venge pro disc can take up to 32mm. What would you recomend?
BMC Granfondo 02 105
Btwin 540
Specialized Venge Pro Disc
Miller
by Miller
From Schwalbe you could have Pro One in 28mm and now in 30mm. There's also the G-One Speed in 30mm, a tyre I really like.
NordicSal
by NordicSal
Miller wrote:
Tue Feb 26, 2019 9:42 am
I have the G-One Allround 35 mm on my Domane, by far my longest lasting tire and first tubeless. I would look at the G-One Speed if I am to set up a more racy bike for sure.
Ettore
by Ettore
I've ridden the G-One Speed as tubeless for 2000 km. I then went to 28mm Pro Ones, and the speed increase is very noticable. Not going back to the G-One Speeds. It's an easy 2 km/h gain.
ms6073
by ms6073
We have G-One All-Around on our gravel bikes, so are the G-One speed more road oriented as opposed to gravel/multi-surface use?
Ettore
by Ettore
ms6073 wrote:
Tue Feb 26, 2019 3:27 pm
I thought the G-One series were primarily aimed at gravel/multi-surface use?
The G-One Speeds are quite different from the G-Ones. Same compound I guess, but the knobs are much smaller and lower. They are supposedly very fast rolling.
jfranci3
by jfranci3
I just looked at this. These are all decent - GP5000 TL is in 28 and 32c. Specialized Roubaix . Schwalbe Pro one (this fit a size up) and G-one Speed (G-one with smaller knobblies). The GP5000 look to roll just as easy as the smaller sizes. The G-One Speed is good for light non-roading, but will be a few watts slower the others because it has a puncture protection belt the normal g-ones don't have (the normal g-ones may actually roll faster despite the tread).
spdntrxi
by spdntrxi
my opinion is g-one speeds are not super fast.. only ok. My estimates are they cost me 20watts
Ettore
by Ettore
spdntrxi wrote:
Tue Feb 26, 2019 4:34 pm
I've not found them to be super fast, but I don't have that much to compare to.
scale29
by scale29
Try the SWorks Turbo 2bliss 28mm, I've been on them a lot last year and really rate them highly, they come out at 31mm on CLX32 rims.
jfranci3
by jfranci3
Oh bummer. Anyone tried Specialized Roubaix Pro 32s? I'm shopping for a 95% road, 5% smooth hardpack tire.
jfranci3
by jfranci3
I just took the G-one speed 30c tires out for a ride. I didn’t have my group or PM with me, but there doesn’t seem to be a speed compromise at 70psi against my 25cPro One Tubeless at 90. Certainly better on road than my 38c Geavelking SKs. Kinda worthless on anything but super hard pack off pavement (esp at 70psi). They were noticeable slow in pretty hard pack, small aggregate trail. There a good 95% road/ 5% shortcut tire and a really good travel bike tire.
Miller
by Miller
G-One Speed is 30mm wide, you don't need to run it 70psi, try 50psi. Won't make you any slower, will be more comfortable, and will be more suitable for off-road.
