Sram Big Chain Ring Issue
Mr.Gib
by Mr.Gib
I installed a new BB30 Sram Red crank. Immediately I noticed that sometimes it would fail to pick up the chain for an entire half rotation. Looked at it on the stand and discovered that two of those four little carbide steel protrusions absolutely will not pick up the chain. The chain just slips over them. I checked my other Red Cranks (7) and they are all fine except for one which also had two of those little protrusions that would not lift the chain. But they were not consecutive so it didn't seem to be much of an issue. On the new crank they are consecutive so you really notice it. Sram will replace the chainring no doubt.
I suspected chain wear but if that was the cause then why always missing on the same spots and never others. Also, I measured the chain and it is not elongated.
I was curious if this was a widespread issue - anyone else had this problem. Couldn't find mention on the net.
dudemanppl
by dudemanppl
Prob FD setup issue then.
Mr.Gib
by Mr.Gib
dudemanppl wrote:
Tue Feb 26, 2019 1:46 am
Good sir, you underestimate me. I naturally tried a spare used ring and indeed it shifts just fine.
2lo8
by 2lo8
I don't have Red rings, but there was something similar for a 50t rival ring I had. I think there were 4 pick up pins in 2 pairs. The problem is the pins should be offset so if one pin in a pair gets an inner link, the other should get an outer link. Instead each pair was timed so both pins an a pair got either inners or outers and the pair on the other side got the opposite.
[6.6kg of no carbon fiber]
[2lo8.wordpress.com]
wheelsONfire
by wheelsONfire
Do you use Etap?
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
