Oversized Pulley RD
addictR1
by addictR1
Anyone first hand or have long term reviews on oversized pulley?
Saw a lot on eBay that spins like crazy. But not sure about long term use or worth while.
It’s definitely cheaper than using CS version.
alcatraz
by alcatraz
Because pulley bearings don't support a big load you have free choice to use all kinds of fragile materials.
The cheap ceramic that would be ground into dust in a wheel hub or bottom bracket can last a long time in a pulley wheel.
Problem I've found is the play in certain bearings. It leads to imprecise shifting.
Also stay away from alloy/metal teeth, stick with softer otherwise you'll have a noisy drivetrain.
addictR1
by addictR1
Thanks. Hadn’t thought about aluminum jockey wheel versus plastic ones.
Seedster
by Seedster
Let's be clear, this OSPW is more a aesthetic addition with little to no real tangible gains. I have two and if the price of admission werent so heavily discounted, I would have passed.
Calnago
by Calnago
Price of admission... into... Supreme Ugliness. No thanks. When the diameter of the imaginary circle that encompasses the entirety of the lower pulley plus the top of the largest cog gets so big as to be larger than the diameter of the big ring up front, then a new era of road ugly has truly taken hold.
This one below is close but not quite there. All it needs is a bigger cassette, like imagine a 40tooth or, oh my... a 50tooth cassette back there. At that point I don’t think you could even call it a “road bike” anymore...
addictR1
by addictR1
Calnago, I know what you mean. I feel like that with disc brake bikes.
Thank for all your info.
Calnago
by Calnago
Well I’m sure you know that I’m totally with ya on the disc brake aesthetic as well. I’ve been calling it the “mountainization” of the road bike for some time now.
addictR1
by addictR1
Calnago wrote:Well I’m sure you know that I’m totally with ya on the disc brake aesthetic as well. I’ve been calling it the “mountainization” of the road bike for some time now.
Lol... mountainization... disc to me looks out of place...
