Shimano Cranks for BB86 Frame
libresse
by libresse
Hi,
I'm fairly new to cycling so pardon the noobish question.
I have a Scott Foil with a bb86 bottom bracket with a SRAM gxp crankset installed in it. I'm planning to switch to Shimano cranks. Does shimano have a gxp type crankset or they just have 1 type of crankset but needs the right bb?
Thank you
FIJIGabe
by FIJIGabe
All you need to do is replace the non-drive side bearing with a standard 24mm bearing and you can run any Shimano crank.
GXP runs a 24mm inner diameter drive side bearing with a 22mm inner non-drive side bearing.
Shimano runs a 24mm inner diameter drive side bearing with a 24mm inner non-drive side bearing.
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
Madone 5, Cobia. I own a lot of Treks.
jfranci3
by jfranci3
bb86 is Shimano. Look on the non-drive side of your GXP Bottom Bracket, does the it have a bearing with a 22mm hole or does it have a 24mm hole with a 1mm thick removable ring? If it has that 2mm adapter ring, you don't need a new bottom bracket, you just don't use the ring.
What a Shimano-GXP spacer ring looks like - https://www.ebay.com/p/Bottom-Bracket-C ... 097&chn=ps
libresse
by libresse
Thanks! So basically there's only 1 type of shimano cranks? unlike in sram theres a gxp and bb30 version.
jfranci3
by jfranci3
Xxx
jfranci3
by jfranci3
Generally, most modern Shimano road cranks are the same size (24mm) . I believe they also make a 30mm version, but that would be far less common. The 30mm sizes are the counterpoint to Shimanos 24mm size. GXP is a workaround to use Shimanos standard by putting a spacer on one of the bearings.
onemanpeloton
by onemanpeloton
I bought a rotor 24mm bottom bracket so that I could use shimano cranks on my giant tcx with BB86
2017 Giant TCR Disc
2015 Giant TCX
2016 Cube Stereo 140
libresse
by libresse
Thank you all. You've all been a big help
