The ideal bar tape (which, when and why)?
themidge
by themidge
chops wrote:
Sat Feb 13, 2021 2:40 pm
What width do you use?
19mm, it was the widest I could find at the time. If there are any wider ones they will be lighter due to less overlap.
mogwaiboi
by mogwaiboi
Image[/url][/img]
Burgh tape is my current fav. Soft, feels really nice to the touch and comes in some great designs.
Canyon Ultimate CF SL
Canyon Grizl CF SLX
Open U.P.
Zero7
by Zero7
What electrical tape do you guys find works best to finish off. One that doesn't leave residue
Zero7
by Zero7
Duplicate
beanbiken
by beanbiken
Zero7 wrote:
Sun Feb 14, 2021 4:08 am
Myself, I use Nitto tape but then cover it with a wrap or two of silicone repair tape.... not really needed but just me.
BB
Coffee & carbon
C36
by C36
Zero7 wrote:What electrical tape do you guys find works best to finish off. One that doesn't leave residue
I gave up on electrical tape and went to silicon self fusing tape. Either black or transparent depending of the bar tape color I use. It as no glue at all, then do no leave any residue and if properly applied, it can’t become lose.
Now, for tape I either used 3m scotch super 88 (0.22mm, thicker than the classic super 33) with above 100degC rating. I also used Tesa tesaflex 4163, thinner (0.13mm) but easier to find.
Overall if you don’t stretch it too much, the tape last way longer.
Envoyé de mon iPad en utilisant Tapatalk
TurboTommy
by TurboTommy
The trouble with electrical tape, and I say this as an electrician. Is that the quality of the tape has gradually got worse over the last 10 years or so. There's a big difference between good and bad tape. And it's effected by temperature.
C36
by C36
TurboTommy wrote:The trouble with electrical tape, and I say this as an electrician. Is that the quality of the tape has gradually got worse over the last 10 years or so. There's a big difference between good and bad tape. And it's effected by temperature.
Curious then what do you still recommend?
TurboTommy
by TurboTommy
C36 wrote:
Sun Feb 14, 2021 10:36 am
Out of the tapes that are available today I'd prob go for 3M tape. I think they have a range of two or 3 tapes which vary in thinkness and pliability etc. What I'm looking for is a tape that has some elasticity to it and isn't too tacky. If you buy a cheaper generic tape you often find they're overly effected by changing temperature and maybe they don't have any give in them. And sometimes the self adhesive nature of them makes them work more like a sellotape than an electricians tape. I think a sign of a good tape is when it's doesn't leave a tacky mark after you remove it.
Kumppa
by Kumppa
Is there way to avoid this sliding happening or due to present-day poor quality of electrical tape? Only slighty tightened Nitto tape.
jlok
by jlok
Ditch the electrician tape and use instant glue to fix the tape instead?
raggedtrousers
by raggedtrousers
Fabric knurl is perfectly decent, light enough, and not expensive. I do recall the bar tape on my TCR advanced pro being very nice, too. Supacaz is bling and feels good but is heavy and expensive.
CyclingGiraffe
by CyclingGiraffe
Went back to plain old Deda Elementi "Logo" tape after messing around a bit with other stuff (Fizik, Lizardskins, etc.). It's cheap, light, easy to wrap, grips well in dry or wet conditions, and is durable and easy to clean.
ArtV
by ArtV
CyclingGiraffe wrote:
Sun Feb 14, 2021 5:57 pm
I did the same.
GZAmk2
by GZAmk2
Fabric Knurl is my favourite
Has anyone worked out how to do the finish taping shown by a few mechs, it looks very narrow like 4-5mm and appears to wrap around the edge of the bar tape and underneath. Must be secured with glue:
https://www.instagram.com/p/CF-II9klx6k ... _copy_link
https://www.instagram.com/p/CK6ZZzoFihJ ... _copy_link
https://www.instagram.com/p/CGV4_ukFB0P ... _copy_link
