mrlobber
by mrlobber on Fri Feb 19, 2021 10:22 pm
Aerohead23 wrote: ↑Fri Feb 19, 2021 8:12 pm
Anyone ordered a custom bike lately? wondering how long it takes to get one?
Ordered one in October, the original date was early March, still confirmed to come late March.
Btw, Orbea also raised prices, however, contrary to some other manufacturers, honors the preorders and these will be handled by the "old" pricing.
If you ordered something right now, I don't think you'd get anything earlier than August, if at all, just as with almost anyone else.
skymasternl
by skymasternl on Fri Mar 05, 2021 2:52 pm
Also ordered a custom Orca OMR back in mid October 2020 in the Netherlands. Was to be delivered in 2nd week of May but apparently it's been moved up to 2nd half of April apparently.
I also received the confirmation email from Orbea saying that the price will not change for us who ordered before the price increase. My LBS didn't even ask me to pay a deposit. Quite neat.
litespeeder
by litespeeder on Wed Mar 17, 2021 8:20 am
Hi guys, i need help on Orca frame size decision. I'm 5'7" (171cm) with 31 inches inside leg. I've the feeling that, beside from Orbeas recommendation, the 51 size maybe is a little bit to small, so better going with a 53. What do you think?
andyw79
by andyw79 on Fri Mar 19, 2021 4:07 pm
litespeeder wrote: ↑Wed Mar 17, 2021 8:20 am
I'm 173cm tall with stumpy legs (29.5 inch inside leg) - went for a pre purchase sizing at a bike fitter and he recommended a 53 for the Orca (haven't ridden it yet so hopefully he was right!).
Janboo
by Janboo on Sun Mar 21, 2021 10:29 am
Ordered my Orca OMX together with an Oiz OMX (lucky me) first week of sept 2020. Delivery was scheduled eind of january for the Orca. Hope to receive the bike end of march. For the Oiz it will be end of april but nothing sure.
As for the size of the Orca, it will be a 53. I'm 181cm tall with inseam 83cm. (32.7 inch). Tried a 51 (too small) and a 55 (felt too big) so ended with a 53.
With 171 and 31 inside legs I would go for 51 but it is af course also preferences.
check6
by check6 on Sun Mar 21, 2021 3:24 pm
Janboo wrote: ↑Sun Mar 21, 2021 10:29 am
Ordered my Oiz August last year. Shipping is scheduled for this Monday, 3/22. Not sure if that is shipping from the distributor, Spain or the moon, but scheduled just the same. The XTR groups was the claimed delay, then the deraileur hanger held it up for over a month. Sure hope it actually shipped this week, but at this point I'm less than optimistic.
check6
andyw79
by andyw79 on Mon Aug 09, 2021 9:41 pm
Has anyone fitted their Orca to a turbo trainer - I don't use them but it will be going on a turbo during a bike fit and the manual seems to suggest you need a specific trainer axle rather than just using the standard one that comes with the bike?
rudye9mr
by rudye9mr on Tue Aug 10, 2021 2:24 pm
What type of axle does Orca currently use?
What type of trainer would be used?
If you know ans the first one, can query from fitter if their trainer is compatible.
andyw79
by andyw79 on Tue Aug 10, 2021 5:11 pm
rudye9mr wrote: ↑Tue Aug 10, 2021 2:24 pm
It comes with a bolt through thru axle - the bike fitter uses a Kickr but hasn't had an Orbea on it before.
In the past I've always just used the thru axle that came with the bike to connect to a turbo but noticed the blue paper says you must use a specific trainer axle (£54 after postage to attach to a turbo once!).
timbo43x
by timbo43x on Fri Aug 20, 2021 10:39 pm
andyw79 wrote: ↑Tue Aug 10, 2021 5:11 pm
You only need to buy that trainer axle if you use a wheel on trainer and you need the trainer to clamp pressure through the axle. I have mine mounted on a Kickr 2018 and no issue. It screws in like mounting your wheel outdoors.
I had the same issue with my bike fitter and they are ordering a wheel on axle from Orbea (kind of them to support it as a one off). But, I'll take the Kickr with me just in case.
wheelsONfire
by wheelsONfire on Sat Aug 21, 2021 9:07 am
How did 55 feel too big? Reach, stack of was it something else?
Noticed 53 comes stock with 170mm cranks and 55 172.5.
Bikes:
Open *UP* (2016.04.14)
xfurio
by xfurio on Fri Oct 15, 2021 8:43 am
TheMadWeasel wrote: ↑Mon Oct 26, 2020 10:36 am
Hello fellow Orbea Orca OMX fans
I am currently in need of replacing my old, aging and unfortunately broken Trek 5500 USPS edition 2003, fitted with Campagnolo Record groupset.
Long story short: the BB shell is broken and completely worn out.
You'll probably see me coming with my question: I am interested in the Orbea Orca OMX, but I actually want to have it fitted with Campagnolo Chorus or Record 12 speed disc. Not because I dislike or dispise Shimano, nor SRAM, it's just that I am so accustomed to Campagnolo (especially the thumb shifters) that I don't want anything else. I tried Shimano Ultegra R8000, but it just wasn't for me tbh.
The question: According to Tarkus in this thread, Orbea has confirmed him that Campa 12 speed mechanical should work but that the EPS versions of Record en Super Record (way above my budget anyway) wouldn't work.
However, when I contacted Orbea myself, they said that 12 Speed campa will NOT work, only the EPS versions of Record and Super Record?!
In addition, when I asked a LBS who is an Orbea dealer, he told me he thinks it might work, while another local LBS Orbea dealer told me it will not work!
So... Can anybody confirm for good that you can build up an Orbea Orca OMX with Campagnolo 12 speed mechanical (either Chorus or Record).
Thank you so much!
Hi.
Answering to the question above, indeed. I just build up my Orca OMX with Record 12s mechanical.
No issues.
