New Continental 5000s tires - the CLINCHER (not TL) thread
AJS914
by AJS914
I think you could have went 25mm on the GP5000.
I have 25mm GP5000TLs on 18mm internal Farsports wheels. I haven't measured them but they seem to be slightly wider than the 25mm rim. BRR claims 26.3mm on a 17mm internal.
Overall I noticed that the 25mm GP5000 is way smaller than the 25mm GP4000. It's sized more like the 23mm GP4000. The other big difference is the height. The GP5000 is quite a bit less tall which would make it easier to remove from a frame.
morrisond
by morrisond
32mm on 21.5 ID Rim - 34.1mm! Nice and still Round.
iamoutside
by iamoutside
Reading through this thread it seems that the internal rim width is the determining factor when determining how wide a tyre will be once seated on the rim. Am I correct to assume that or is the external width of a rim the determining factor? I am looking at getting rims that measure 18mm internally and 26 externally and wondering what the true width would be with a 25mm GP5000's.
Hexsense
by Hexsense
iamoutside wrote:
Mon Mar 09, 2020 12:20 am
Internal width determine how wide each tire will become once pumped.
External width determine how wide a tire can be before it start to effect aerodynamic of the rim in a bad way...
So with 26mm external width, you want the tire to measure UNDER 26mm (under 24.74mm, if possible). This only apply if you want best aero performance.
That's be 23c GP5000 territory. 25c GP5000 at 18mm internal width can become wider than 26mm.
pdlpsher1
by pdlpsher1
23 and 25 GP5k are poor choices. You'll get more benefits out of the 28s and enjoy the plush ride more. When you are comfortable you can push more watts, negating any aero penalties the 28s may have.
Sent from my KFMAWI using Tapatalk
Jugi
by Jugi
pdlpsher1 wrote:23 and 25 GP5k are poor choices. You'll get more benefits out of the 28s and enjoy the plush ride more. When you are comfortable you can push more watts, negating any aero penalties the 28s may have.
It depends. My "sweet spot" for tire width is around 24mm. Anything wider than nominal 25mm feels too spongy under sprinting out of the saddle. It seems I ride on better than average roads, as I don't see any need for increased comfort.
However, switching from 23 to 25mm as my TT bike's rear tire definetly made me faster. With a 23mm at the TT bike's seating position, any bigger road imperfections felt like the bike tried to kick my nuts. 25mm tire enables me to just push over those.
rides4beer
by rides4beer
Jugi wrote:
Mon Mar 09, 2020 11:57 am
Yup, everyone will be different. I went with 25mm GP5Ks for my new wheels, forgetting how much of a difference 28mm makes for me on our crappy roads (I'm 86kg), so I'll give up the aero watts for comfort watts and go back to 28's. :thumbup:
tleo
by tleo
Has anybody mounted the 28's on a wheel with an ID of ~22mm? My 28 GP 4000s II measure almost 32mm exactly on these wheels. I've heard the 5000's are closer to their stated size but how much closer? I've kind of come to like the 4000's on the crappy roads around here.
Thanks.
Reno
by Reno
tleo wrote:
Tue Mar 31, 2020 2:01 am
Thanks.
I mounted GP5000 28mm on a wheel with 21.5.mm ID. I have a picture of that in the Allez Sprint topic and don't know how to find the post from my profile - I think they came up with approx. 31mm.
EDIT: This page of the Allez Sprint topic:
viewtopic.php?f=3&t=133529&start=1395
tleo
by tleo
Reno wrote:
Tue Mar 31, 2020 11:00 am
Perfect. Thanks.
tabl10s
by tabl10s
Deleted.
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's).
2016 Rca: 11.07lbs/5.048kg.
2018 Rca.
2018 S-Works SL6 Ultralight: 12.03lbs.
pdlpsher1
by pdlpsher1
28mm on 21mm ID rim = 30mm wide. 32mm on 21mm ID rim = 33.5mm wide. Hope this helps.
tleo
by tleo
pdlpsher1 wrote:
Wed Apr 01, 2020 6:03 am
Thanks!
JMeinholdt
by JMeinholdt
I know this is about the non-TL GP5k, but I'm sure sizing is similar. My 25c on 19mm internal rims measure just shy of 27mm (26.96mm).
Wilier Cento10AIR Rim Brake - SRAM Force AXS
BMC GF02 - Ultegra R8000 - Commuter/Trainer
Strava link: https://www.strava.com/athletes/jmeinholdt
morrisond
by morrisond
morrisond wrote:
Mon Feb 17, 2020 8:51 pm
Just some quick feedback on these. Last year I had the same tires on 17mm ID wheels (Shamal Disc) running about 85-90 psi - to where they weren't too squishy for my weight and handled well (I am a clydesadale well over 100kg).
Now on the 21.5mm id Wheels (i9 AR25) I'm down to 60/65psi with no squishiness and absolutely amazing ride.
I am totally sold on wider ID wheels. I just wish Campy (my favourite wheels/hubs) would make something wider than 19mm ID.
32mm Tires are amazing!
