New Continental 5000s tires - the CLINCHER (not TL) thread
Robius
by Robius
Undisputed 5w RR gain per pair is worth a few more dollars.
2016 Felt AR2
dim
by dim
I've been using the GP5000 clinchers (32mm wide) on my Miyata 1000 bike. I've ridden in pouring rain, potholed roads, over broken glass etc and I am very impressed with these. I use the bike as my daily commuter (approx 40-50km/day)
so far, I am nearing 4000km on these and have had zero punctures (I normally start getting punctures on other tyres around the 2000km mark on the roads that I travel)... I have not switched tyres front to back .... they still look good aswell
I'm in the process of having new wheels built (HED Belgium Plus rims, Son Deluxe dynamo hub, Supernova E3 Triple dynamo light plus the rear Supernova light, and a powebank charger) ... I should have the new wheels in a week or so, and I will fit Continental GP5000 TL (tubeless version in 32mm)
I'm using the tubeless version (25mm) on my Trek Emonda SL6 and on that bike, I have just over 1600km with zero punctures
Grip and wear is good, they are fast so buy them, they are very very good IMHO (I never liked the GP4000 and found that Specialized Turbo Cotton were a much better tyre)
Trek Emonda SL6
Miyata One Thousand
sychen
by sychen
How do they compare with turbo cottons? They have been my tire of choice for the last year.
dim
by dim
sychen wrote:
Sun Sep 22, 2019 2:31 pm
Turbo Cottons are very good, and they were my tire of choice before GP5000 .... The GP5000 are more durable/longer lasting and are faster. I have not tried the Turbo Cotton Hell of the North (28mm wide) yet and will try them in the future
I've used Turbo Cotton (25mm wide) during pouring rain and during winter, and they were fine
Trek Emonda SL6
Miyata One Thousand
tomycs
by tomycs
No punctures today on first wet UK ride (about 800 dry kms before this) on 25mm GP5000 but not impressed either, a fair amount less grippy in the wet than Schwalbe One (2017+) or the old GP4000SII.
Marin
by Marin
Did you crash? If not, how did you test the grip?
tomycs
by tomycs
I can feel a tyre losing grip without crashing. I also adjust my speed going through corners after that and eventually reduce air pressure.
dim
by dim
tomycs wrote:
Wed Oct 02, 2019 10:53 am
Nah ... you are doing it wrong ...
I wake up in the morning, get ready for work, have a coffee, and just before Im about to leave, I check my tyres by squeezing them with my thumb and forefinger ...
(just in case I've got a slow puncture from my previous ride) ...
no need to be like Evel Knievel going around corners on tyres that are not properly inflated, then letting out more air :)
Trek Emonda SL6
Miyata One Thousand
dim
by dim
I eventualy got a puncture on the rear tyre (GP5000 32mm clincher) .... 4,211.3 km and bear in mind that I have 2 large pannier bags loaded with heavy equipment on crappy roads
I've just switched to some other tyres I have had lying around (IRC Aspite Pro Wet) .... these will be used till the end of the month until my new wheels are built (I will use the GP5000 tubeless version in 32mm)
so guys, maybe I was lucky, but I highly recomend these ... amazing tyres
Trek Emonda SL6
Miyata One Thousand
sceptre
by sceptre
A question that I couldn't find an answer to within the thread :
Can a GP5000 (not TL) be used tubeless ?
I have a set of 28's but I'm finding clearance in my frame is a little too snug at the rear, so looking to get a 25 instead.
My rims are road tubeless ready (no spoke holes) so also considering switching to tubeless if I can.
4ibanez
by 4ibanez
Just looking at getting some more tyres in, so figured out the lifespan of my GP5000s to date. May be useful to know.
23mm front had almost exactly 4,500 miles before the 1st puncture. As winter is starting to set in I'm finding flint in it every 1 or 2 rides since then. Only done another 100 miles or so since the puncture, but looking like time to replace.
The 25mm rear got 2,750 miles ish into it before I replaced it (after puncture number 2 & 3 in 2 consecutive days). It got its 1st puncture about 70% through this time with a big sharp bit of flint. The replacement rear (25mm) has about 1,750 in it so far, and is starting to get some cuts. Am thinking about moving this one to the front and put a 28mm GP4000s that I picked up cheap. I really don't like the idea of slow tyres even in winter!
TriJoeri
by TriJoeri
I didn't read through the entire thread but did someone else notice these showing the wires on the sidewall quite early already? They have less than 500km on them and I can already see the wires through the rubber on the side where the Conti logo is. 23mm on a 19-25mm (internal-external) width wheel with 7 bar of pressure.
IvanZg
by IvanZg
Those nylon threads (or whatever they are) where showing on my pair from early beginning. I got rid of them when side wall blew up after cca 1000km.
AJS914
by AJS914
sceptre wrote:
Sun Oct 20, 2019 5:02 pm
You could try and go "ghetto tubeless" with the non-TL tire. The beauty of the TL tire though is the inner butyl layer. It keeps the sealant from weeping through sidewalls. The tire seals up incredibly well and the sealant lasts a long time.
I just setup 25mm GP5000TL and have been really enjoying the tires. They feel very fast. I haven't a flat yet that I've noticed.
slake21
by slake21
anyone here using a 19mm internal rim?
my 25mm 4000s were close to 28mm which made taking the rear wheel out very difficult
that's why I ordered 23mm 5000 hoping it will actually be 25mm (for my 24mm external rims)
but now I'm no so sure about my choice :?
