2018 Cervelo R5 Disc build
mrirocz
by mrirocz
Hi everyone,
Just got my R5 frame set tonight and super excited to share some pics! I have most of the parts to complete the bike already. This project will be based on around DT Swiss wheelset, Lighting Cranks, and etap groupo!
Here some quick pics of some parts mocked up!
jlok
by jlok
The crankset looks great with your R5. What's the expected weight of the final build?
mrirocz
by mrirocz
GP 5000 Tubeless tires are on. These did not go on without a struggle, but I was able to put them on without a tire lever. It was definitely difficult and I thought I would burst a brain vessel, but she it starting to finally look like a bike!
mrirocz
by mrirocz
Finally out of the shop! She weighs in at 15lbs flat without pedals.
Here are the specs:
2018 51cm Cervelo R5 Disc
SRAM RED ETAP
DT Swiss ARC 1100 wheelset
28mm Continental 5000tl tires (running tubeless)
Lightning Cranks with Extralite 50/34 chainrings
SRAM Red 11/32 Cassette
Cervelo 90mm stem
Cervelo Seat Post
Cervelo Handlebar
KMC X11SL chain
Fizik Antares Saddle
Extralite Top Cap and Steerer Nut
Replaced front and rear R.A.T thru axles with "Robert Axle Project"
I will be getting an Extralite Stem and a lighter saddle, so the weight will keep falling. I will also need to adjust the spacers on the steerer as I think they are a bit high.
mrlobber
by mrlobber
Did your bike come with non-setback seatpost straight away? If not, do you still have the setback one, and could compare the weights between setback and non-setback versions? Thanks.
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
mrirocz
by mrirocz
mrlobber wrote:
Thu Mar 28, 2019 8:26 am
Hey there, the 48/51cm come with the straight seatpost from factory. I do not have the setback for comparison unfortunately.
willmac
by willmac
Is your front tire on backwards?
mrirocz
by mrirocz
willmac wrote:
Thu Mar 28, 2019 9:09 am
Good catch! Putting these tires on was a bitch, so it's probably going to stay that way for sometime! :mrgreen:
stevod
by stevod
188g inline / 208g setback - both including saddle clamp and bolts
mrlobber
by mrlobber
stevod wrote:
Thu Mar 28, 2019 9:39 am
188g inline / 208g setback - both including seat clamp and bolts
Cool, thanks! :thumbup:
sychen
by sychen
Those aero bars looks like it's on backwards..
Used to the wings being behind the centre line, not in front.
From a hand position standpoint it makes sense.. From an aero perspective not so much.
crlincoln
by crlincoln
I had to put some tubeless 5000’s on a set of DT Swiss 1600’s, they were the most difficult tyres I’ve ever had to mount...
TiCass
by TiCass
sychen wrote:
Thu Mar 28, 2019 12:03 pm
The thing we don't realize with typical aerobar is that they effectively reduce the space between your knees and the bar by about 2cm. On the flat, it's no problem, but on steep incline, my knee comes very close to my Pro Vibe Aero handlebar. Cervelo design is odd, but makes sense.
dricked
by dricked
Any idea how much that stem weighs?
mrirocz
by mrirocz
dricked wrote:
Thu Mar 28, 2019 1:33 pm
I'll weigh it later since I am replacing it with an Extralite unit.
