Wrong. Some manufacturers used to build electric/mechanical dedicated frames only (Time did for sure) but now most all frames are dual use. Mechanical isn't going away. i preferred the dedicated frames, specifically external routing for mechanical as there is much less drag caused from internal routing.
Which Groupset to choose in today's madness
Totally agree. Also, the new rear mech has a much shorter cable and the front mech completely hide the cable. It's a very nice groupset. The shifting performance gap with electronic has been reduce with the 9100.
Thanks to all who replied, plenty of interesting points again. I hope this will help others as well.
To those who asked, the frame will probably be an SL6 Disc, although I am still toying with the idea of a Venge (which will make choices easier being electronic only). Not that it matters necessarily.
What I'm seeing is that SRAM and Campagnolo may have some advantages, but overall Shimano may represent the wisest option (unless one wants to build a Colnago or similar Italian/custom steed).
I'm getting the idea that a "best" course for somebody like me with a non-infinite budget would be to:
- if electronic, go for Ultegra Di2 and potentially swap cranks/cassette over time if one really wants to shed some weight.
- if mechanical, go for DA (or Record 11sp if going with Campy).
To be honest I kinda like the looks of Campagnolo (I'm a sucker for carbon looks). But I've never tried it and it seems like it would be a love-it-or-hate-it situation. Aaand looks, at least for groupset choice, should not matter that much. I think.
I think you listed all the reasonable contenders correctly. I would not recommend putting something on with the thought of upgrading it later (apart from parts that wear out) - bottom line it will be more expensive, plus its pretty likely you will always have this in mind and never be really really happy with your bike. From my experience Ultegra DI2 is just great, given that's at a good pricepoint for you that would be my pick. Moneywise the jump from Ultegra DI2 to DA DI2 doesn't really make sense, so wouldn't be too worried about that. eTap disc is a really good groupset as well, though personally I don't think it's worth the additional money over Ultegra DI2 - also I think the lever hoods on eTap disc are a bit too bulky, but that's just personal preference I guess. If you go the mechanical route, just make sure you invest in a good set of cables, that really makes a huge difference.
The bad news is that there's a lot to pick from, and a lot to consider. The good news on the other hand is that given you're options there's really no bad groupset in your list - they're all pretty great!
I had someone mistake my r8000 front for a Di2 setup, because it's so clean looking. I've never used electronic, but shifting is perfect on mine, and the direct mount brakes are fantastic.
Pick the one with the hood shape that feel best in your hands. Like a saddle, you'll be in contact with it for pretty much the entirity of your ride. You can get used to Ultrashift, Double Tap and Shimano style very easily - each has advantages and disadvantages and that in itself is not a showstopper.
There's no reason to avoid 11 speed just because 12 speed is out. A bonus of 11 speed (other than reduced price, now) is that cranks, cassettes and chains are all interchangeable. No idea what Shimano will do, but already between Campagnolo and SRAM, 12 speed looks like it's going to pin you down into a particular standard.
There's also no need to go electronic - good mechanical groups (Campy C/R/SR and Shimano DA/Ultegra) are very, very good. They're lighter, cheaper and it cost less to replace parts as necessary.
As has been said, lots is changing right now... I'd get something 11 speed and enjoy it while things play out.
Actually he’s right. You rarely used to see a frame set that wasn’t available in a mechanical variant but now they are arriving that will never support a mechanical variant (i.e. Venge). Given it’s driven by cable bends required for full cable integration, which is only become more common, it’s safe to assume we’ll see a lot more electronic only framesMyM3Coupe wrote:Wrong. Some manufacturers used to build electric/mechanical dedicated frames only (Time did for sure) but now most all frames are dual use. Mechanical isn't going away. i preferred the dedicated frames, specifically external routing for mechanical as there is much less drag caused from internal routing.
- wheelsONfire
Best bang for buck is Shimano Ultegra Di2 or (1 gen) Sram Etap.
Bikes:
Open *UP* (2016.04.14)
- wheelsONfire
Discodan wrote: ↑Wed Feb 13, 2019 9:15 amActually he’s right. You rarely used to see a frame set that wasn’t available in a mechanical variant but now they are arriving that will never support a mechanical variant (i.e. Venge). Given it’s driven by cable bends required for full cable integration, which is only become more common, it’s safe to assume we’ll see a lot more electronic only framesMyM3Coupe wrote:Wrong. Some manufacturers used to build electric/mechanical dedicated frames only (Time did for sure) but now most all frames are dual use. Mechanical isn't going away. i preferred the dedicated frames, specifically external routing for mechanical as there is much less drag caused from internal routing.
My Ax Lightness Vial EVO Race, is Etap version. No holes except for rear brake.
Bikes:
That's also a fair point. I didn't expect hood shape to be that big a factor, but I guess I would have to touch some hoodsrobertbb wrote: ↑Wed Feb 13, 2019 12:29 amPick the one with the hood shape that feel best in your hands. Like a saddle, you'll be in contact with it for pretty much the entirity of your ride. You can get used to Ultrashift, Double Tap and Shimano style very easily - each has advantages and disadvantages and that in itself is not a showstopper.
Remember also that the hoods will impact the reach. I'd say there's a 1.5 to 2cm reach difference between Campy 11 (shorter) and Shimano/SRAM (longer). With the Campy hoods you also get a little more height available optionally with the pistol grip available up top.
People go nuts about stem length and bar reach and then slap on their existing/chosen shifters without even giving this any thought which I always find strange.
Get the best bike you can afford and still not be divorced. Groupsets (high end) are almost always cheaper on a new bike because manufacturers get bulk discounts. Only in the very high end does it pay to build your own bike with sourced components.
Also, you are on the ww forum for a reason. Don’t buy that heavy groupset because it was sensible. It will eat away at you. Get etap at clearance prices. I think it will be the best fit of price/weight/on trend.
