First powermeter - P2M NgEco / Favero Assioma Duo
pdlpsher1
by pdlpsher1
Thanks for the detailed response Eugene. Well, maybe it's a good thing that I only own one PM. I really do think that minor anomalies are just the nature of the beast on PMs. I have read many of DCRainmakers' PM reviews and basically he's saying that most of the mainstream PMs are very good in terms of accuracy. If you look at the power data in detail you'll never see two PMs read the same. One will be higher at times and lower at other times. Now I think 5% diff. is quite substantial and I hope those are very isolated incidents (you mentioned 2-3 sessions out of 100).
On the power loss between the Quarq and Vector, I gave it more thought and I think you are correct. The Quarq is calibrated with a known weight at the pedal axle. So the power reading on a Quarq is determined by the amount of force applied at the pedal. The power measurement ignores the flexing of crank assembly and also any frictional losses in the BB bearings.
TobinHatesYou
by TobinHatesYou
pdlpsher1 wrote:
Sat Feb 09, 2019 7:58 am
I think that yes, instantaneous power may differ from one recording to another due to the nature of polling rates and filtering, and I do think that most power meters are sufficiently accurate. Averaging power over 60 minutes should result in numbers within 1-2W. I don't mind when the Quarq is within 1-2W, it's more the rare occasion where it jumps to ~10W off that bugs me.
The Quarq is one of my newer PMs, so I probably only have 30 or so indoor sessions with it. A handful of rides out of 30 with it being pretty far off is a bit more substantial than the 100 total with various combinations. It's enough data, though, to see trends and I am confident that the Quarq's numbers are more variable than the others from ride to ride.
Perhaps my particular Quarq is faulty, but its offset never varies more than 20 when they say 50 is acceptable. I need to add a P2M to my collection at some point.
Pinguin
by Pinguin
TobinHatesYou wrote:
Sat Feb 09, 2019 8:11 am
Tobin if you buy a new Pm now,which one would you choose?
TobinHatesYou
by TobinHatesYou
Pinguin wrote:
Sat Feb 09, 2019 5:12 pm
Favero Assioma Duo.
Pinguin
by Pinguin
I have no decision about those P2max and Assiomas
Technical aspect i think the P2max is bulletproof,but the Assiomas are not troublefree and have some Softwareproblems what i read in the past more than P2max
Price is on both very good compare with Srm
All in all i think P2max is the little better choice
cnynrpr
by cnynrpr
I currently own Powertap P1 pedals and just bought the NGeco. The P1 has had bearing wear every 1-2 years or so, they're not user replaceable. The Favero assioma seems to have user replaceable bearings for $37 for the kit, so that would be nice, it is something I would account for with owning power pedals (at least it is for the P1, I'm only assuming with the Assiomas).
My suggestion is if you travel and rent bikes many times during the year, the Favero Assioma would be the one I would get and in fact, I plan to purchase them when the P1 pedals go caput. I would account for bearing service costs with owning power pedals based on my experience, albeit with a different brand. If you never ever travel and rent bikes then get the NGeco, simpler.
AZR3
by AZR3
cnynrpr wrote:
Tue Oct 22, 2019 1:46 am
That's a big plus for the Assioma pedals, you can replace the bearings or even the entire pedal body without sending it out.
backdoor
by backdoor
I just bought a pair of the Assioma pedals. Quite a few reasons I went with them -
1. Cheap. Duo option for less than $600usd shipped, Uno for $400
2. They are fairly simple. It's basically an Xpedo pedal with a power meter on the spindle. Xpedo builds many of their pedals on the same axle. This means you can swap out the pedal with many other Xpedo pedals including their (slightly) lighter SL carbon pedals or one of their SPD pedal bodies. So you can have power based SPD pedals. All the parts (even the power meter spindle itself) are replaceable.
3. Easy to swap between bikes. Can travel with you and throw on rental or borrowed bikes.
4. Amazingly accurate.
5. They now support Cycling dynamics and power phase.
Sent from my SM-N950U using Tapatalk
TribesMan
by TribesMan
I've been using Assioma Duos for 18 months now, around 19.000km ridden.
Not one issue with them, rock solid.
Clip-in is a bit tighter compared to standard Look Keos, but you get used to it.
Battery life is easily over 50 hours.
I can't recommend them enough.
robertbb
by robertbb
backdoor wrote:
Tue Oct 22, 2019 6:38 am
6: more environmentally friendly as they are recharegable (don't throw batteries away)
7: more convenient (won't need to keep a stock of batteries on hand)
8: lower stack height than any other PM pedals
9: lighter than any other PM pedals
10: The electronics are inboard, so way less likely to get damaged in a crash
11: the sealed resin design is superior in every way...
Boshk
by Boshk
Assioma if you have or plan to have more than 1 bike, P2M if you only have 1 bike. Only heard of good things about the P2M
JasperGr
by JasperGr
Was in the same ship. Finally i chose for the pedals because i really like the info about the balance. I came from the shimano cleats but the Xpedo pedals are worthless so i bought the look grey cleat. Less float and they fit better in the pedals. Now it's on par with the shimano cleats. Stage pm were also on the list but when i saw the incorrect numbers review at youtube they were off the list.
Verstuurd vanaf mijn SM-G973F met Tapatalk
naylor343
by naylor343
Boshk wrote:
Mon Nov 25, 2019 1:53 am
I run a P2M type S on 3 bikes. It takes no more time or effort to swap the chainset between bikes than it does to change a pair of pedals.
JasperGr
by JasperGr
If the bottom bracket is the same yes, otherwise no.
naylor343
by naylor343
JasperGr wrote:
Sat Jan 25, 2020 5:58 am
Yes, point taken. In this case, pedals will be the way to go. I forget as all my bike are Giant with BB86
