Currently F8, but want to upgrade to disc brakes
First of all, I absolutely love the decending of the Pinarello F8, tracks perfectly and it feels amazing just sweeping around corners. I'm realizing that I can decend much faster than I can brake (which is what's holding me back), so I'm seriously considering changing to disc brakes. The obvious answer would be to get an F8 or F10 disc frame, but since I'm looking to switch, is there another frame I should look at? Fit of my 54cm is perfect (stack 550, reach 386).
I've stated what I love about the F8 (decending, balance, power transfer), but it's not always the most comfortable frame (it can leave you a bit beat up after long rides, especially on rougher pavement).
- VTR1000SP2
If your F8 is perfect, I would stick with a disc bike that has the same geometry so the only difference is the brakes.
I agree with the geometry comment.
Apart from that, I wonder what rims, pads and brakes you are using? I tested some disc brake road bikes (sram and shimano) and to be honest, braking was not stronger than rim brakes (Shimano and Campagnolo I tested before).
If you want to improve the braking power, I guess checking that three components will be better for you. If problem is modulation or overheating, then I guess disc brake makes sense.
Enve 4.5 Gen 2 with Enve brake pads. EE brakes (everything else Campy). Living in a fairly mountainous area, long decents does worry me (and I do feel like I'm starting to lose modulation towards the end of the decends, especially if they are a bit technical).ToffieBoi wrote: ↑Sun Feb 03, 2019 10:48 amI agree with the geometry comment.
Guess the concensus is to stick with a Pinarello (I've never had a bike fit me this well! and that's after 25+ years and quite a few years of racing).
In the end, it is all about happiness. F10 Disc will brake as you want and geometry will put a smile on your faceaudiojan wrote: ↑Sun Feb 03, 2019 4:41 pmEnve 4.5 Gen 2 with Enve brake pads. EE brakes (everything else Campy). Living in a fairly mountainous area, long decents does worry me (and I do feel like I'm starting to lose modulation towards the end of the decends, especially if they are a bit technical).ToffieBoi wrote: ↑Sun Feb 03, 2019 10:48 amI agree with the geometry comment.
Disc brakes are a downgrade.
Seriosuly though, I've almost hit 60 mph descending on rim brakes. Only issue I ever had was descending in the rain, and even then I did it, just not as fast. Having test ridden disc-equipped bikes I don't really buy that you can descend faster on them, if the implication is you brake harder and later into corners. Traction is your issue there, and you don't really need to run wider than 28s. Just my opinion though. There's ample reason enough to switch to disc brakes if you want.
I agree with others though for sure: get an F8 disc or check the geometry of the F10. If it's close enough to the F8 you have then maybe get an F10 disc. Don't try to fix what isn't broken.
I second thisToffieBoi wrote: ↑Sun Feb 03, 2019 10:48 amI agree with the geometry comment.
Aside from this, if its not broken don't change it.
Ok, so it seems like the concensus is that disc brakes may not give me what I'm looking for... I can swap the brakes for Campy (although I'm not sure they are that much better than EE, it's not like they are crappy...). What about brake pads? I'm using the Enve carbon pads for the Gen 2 and they work ok, but not great. I can honestly say that my 6.7's (gen 1 brake surface) with Reynold Cryo Blue brakes just as well. Are there any other pads that I should try out with the Gen 2 track? A whole lot less expensive than changing the frame and going to disc...
Campagnolo pads for carbon (red ones) works great in my experience, although I didn't have a chance to try them on Enve.
Bah humbug. Get the disk brakes. Too many people here talking their own bikes and reconciling their own past decisions. They'll be riding disk soon enough as rim brakes fade away into obscurity in the coming years.
For my part, get the F8 disk with the thru axles. There are still a few around and you can get a great deal on them. As stated earlier, the bars and stem swap right over. Ditto the saddle and pedals and candidly the front and rear mech if you are happy with them. Else, get the groupset of your choice.
It makes no sense to spend $6,000 just to switch from rim brakes to disc brakes.
How is not being able to brake hard enough holding you back? Are you racing down the alps in the Tour? Are you racing at all?
Have you ridden a disc brake bike so that you know that discs brakes so much better? The only enormous advantage I see with disc brakes is when it's wet out. How often are you riding and descending in bad weather?
If the F8 isn't as comfortable as you like, try some wider rims, tires, and a little lower pressure.
audiojan wrote: ↑Sat Feb 02, 2019 6:42 pmI'm realizing that I can decend much faster than I can brake (which is what's holding me back), so I'm seriously considering changing to disc brakes.
(snip)
First of all, why does it matter if I race or not? And yes, I do ride even if the weather is less than stellar.AJS914 wrote: ↑Tue Feb 05, 2019 6:13 pmIt makes no sense to spend $6,000 just to switch from rim brakes to disc brakes.
I do have wider tires (25's, can't fit much larger with the ENVE 4.5's and the F8), lower pressure (96psi). There's just not too many wider rims out there that would actually fit the frame...
