Specialized S-works Tarmac SL6 bottom bracket question
matenadasdi
by matenadasdi
Hi everyone,
I've just purchased an S-works tarmac sl6 frameset with the default ceramic speed OSBB bottom bracket in it.
I'm planning to finish the setup with Sram Red Etap and a Quarq Dzero Power Meter Crankset.
I've made some research to find the best answers about spacers, new bbs, etc. but I ended up asking it here because I hope someone has first-hand experience.
Should I purchase the new Quarq with the BB30 or GXP version? Should I change the default OSBB ceramic speed bottom bracket to make this setup work or are there some spacer packages available which solve the issue for me?
Thank you in advance!
ryanw
by ryanw
I 'think' you just want the BB30 Quarq, and run it without the large NDS spacer.
Again, not entirely sure on the BB setup, but could be a CeramicSpeed PF30 with 24mm adapters.
NiFTY
by NiFTY
OSBB is essentially a PF30 (30mm spindle, 68mm bearing width). quarq BB30 is essentially a 386evo (30mm spindle, 86mm bearing width). So the bb30 quarq + 18mm of spacers is the way to go (they will come with the quarq).
matenadasdi
by matenadasdi
NiFTY wrote:
Thu Jan 31, 2019 12:18 pm
Oh, this sounds cool! So does that mean that I don't have to buy anything just the BB30 Quarq which provides spacers and the original OSBB bb in the frame will work with it? :shock:
NiFTY
by NiFTY
Yep. Both use a 30mm spindle. Quarq is just bb386 compatible. Think there should be a 11mm drive side, 5mm non drive plus a threaded spacer to do preload. Works out to be a bit over 18mm.
ryanw
by ryanw
Yep. Or you can buy a C-Bear bottom bracket which is machined with the spacer as part of the body (less moving parts, less squeaking)...
scale29
by scale29
Just go with the BB30 Quarq, don't go changing the bearings as you'd be junking £200+ worth of ceramic bearing.
fuel2000
by fuel2000
I have the quark zero with a gpx spindle. I used the cbear bb. You just use the wavey washer with this set up. No noises just works. I sold the supplied ceramic speed bearings on eBay and they paid for the cbear😀👍
Stendhal
by Stendhal
fuel2000 wrote:
Thu Jan 31, 2019 6:18 pm
Exactly what I did (other than skipping the Quark meter on the GXP Red spindle). Very pleased.
Cervelo Aspero (7.75); Orbea Orca OMX (7.30)
Retired: S-Works Tarmac SL6, LOW// mki, Pinarello Dogma F10\F8, Lapierre Pulsium, TIME Fluidity, Wilier Cento1 SR, Ridley Noah, Cyfac Cadence, Cervelo S2\R3\R5, Felt Z25, Klein Quantum, Cannondale 2.0
cerro
by cerro
OSBB on the Tarmac SL6 is a standard BB30, not PF30. Except that I agree with you
/jonas l
NiFTY
by NiFTY
Cerro i had no idea they changed bb dimensiom whilst keepimg the same name. Thats retarded.
DartanianX
by DartanianX
What’s even more crazy is the Cannondale Super Six Evo Hi-Mod is PF30a but has a BB30 logo on the frame.
Riddle me that
Calnago
by Calnago
Some time ago OSBB also had a 61mm shell width. Very bad idea.
cerro
by cerro
NiFTY wrote:
Sun Feb 03, 2019 12:36 am
No matter if the frame is OSBB old style like Calnago writes about, if it's BB30, PF30 och PF386 they use the name OSBB. A bit confusing if you can't see the frame yes.
/jonas l
Swannie
by Swannie
My SL6 has now + 8000 km's done, in fair conditions, when it rains i'm on my mountainbike. After this mornings ride when i heard some creaking noise, i checked my crank's for play on the BB.
It seems my Ceramic speed is already wasted??
Is this normal for Ceramic Speed?
