Good rim brakes between Dura-Ace and EE
snaxez
by snaxez
I plan to do more mountains this summer and I`m looking for new calipers for my Scott CR1 SL. Currently I have Planet X Ultra Light CNC Brake Calipers (203g pair), but the braking is not the best, and I allways have to fiddle with them, as they will not center properly. I think the best WW brakes with good stopping power are EE, but I just can`t put out 550€ for calipers. Other option would be Dura Ace BR-R9100, but they are 326g per pair. That seems abit on the heavy side.
Dura Ace BR-9000 brakes seem to be lighter at 297g per pair. Is there any differfence between 9000 and 9100, and are there any other good options between DA and EE?
mcflurry
by mcflurry
Have you considered SRAM force? Unless mismatching components bothers you, at 280ish grams they are the best bang for buck ;)
c60 ultegra bora
caad12 force r0
caad10 record zonda
alcatraz
by alcatraz
Try different brake pads.
The Planet-X are hard to beat weight and pricewise. The performance is actually really good when they are working properly.
Maybe check the brake arms for sideplay. They might just need servicing/preloading.
Sometimes playing around with the centerbolt and holding on to the axle with a cone wrench can actually undo the preload on the brakearms.
As for centering make sure your brake housing is the right length. Rotate the handlebars and check that the housing isn't pushing or pulling on the calipers.
Unscrew the spring tension bolt fully. It's useless. To center I don't even use a cone wrench anymore (only sometimes if I haven't done it for a long time). What I do is make sure the threads are greased and then tighten the recessed nut until it's tight. Of course the centering will be completely off at this point. If the caliper needs to rotate back a bit I just put some loosening pressure on the recessed nut and nudge the caliper into the right position with my other hand. Done. No need to touch any small screws. All you need is the allen key. It's even faster than playing with the adjustment screws and I've done it on sram and shimano brakes and it works great and stays centered for a long time. Lots of sweat and frustration spared.
jih
by jih
The PX brakes work ok, especially for their weight, but not as well as the standard groupset road brakes. I had them for several years on my lightest bike.
ryanw
by ryanw
Had both DA9000 and latest EE.
DA definitely more feel and less flex, but I'm 85kg.
EE still up to the job and very good, 120g odd lighter, and obviously flasher = most important.
'16 Cervelo S5 - 6,650g RIP
'17 Focus Mares Force 1 - 7,170g
'19 Cervelo S5 Disc - 7,460g
IG: RhinosWorkshop - Check it out for all my custom builds :thumbup:
:!: Ride Southern Spain Cycling Holidays *£445 for 7 Nights* :!:
bikebreak
by bikebreak
I've had the Planet X brakes, they are ok but not great. The SRAM red aerolink is similar but easier to center and has more power. It's not as powerful as my ultegra brakes but I would say it's a viable middle option btwn the Planet X and heavier Shimano
bikebreak
by bikebreak
caveat:
The new Shimano brakes need their own brake levers for best function, Shimano changed the pull ratio for the 11 speed groups
the Planet X and SRAM red brakes work with everything but would be less than ideal with Shimano 11 levers
Philbar72
by Philbar72
the old 9000 brakes are lighter than the current 9100's but only support up to 25mm tyres. 9100's support 28mm.
they are the best rim brakes on the market i'd say. despite their bulk...
icantaffordcycling
by icantaffordcycling
mcflurry wrote: Have you considered SRAM force?
IMO SRAM force brakes are pretty bad and I prefer ultegra and 105 to them any day (I am guessing DA is even better but I ain't got no money). Mine may have been a little old and seized up but Shimano brakes definitely have more power and modulation than SRAM Force brakes.
MyM3Coupe
by MyM3Coupe
I have the TRP R979 magnesium alloy brakes and love them. Modulate and stop beautifully and are quite lightweight.
cwdzoot
by cwdzoot
Something good about the eeBrake is the extra clarance they offer, if you are running taller tires or the caliper limits tire size not the frame than the ee are the best.
Shimano still feel better than anything else but the ee Brake feels great for it's weight
Instagram - stylish square bike pics
Flickr - over 20 million views for good reason
Facebook - friends get the good info & coupons first
markdjr
by markdjr
ryanw wrote:
Tue Jan 29, 2019 1:41 pm
My experience as well.
mcflurry
by mcflurry
Having both force22 & ultegra6800 brakes, with both setup correctly I could barely tell the difference. Braking power and the progressiveness is better then any third-party brakes imho.
c60 ultegra bora
caad12 force r0
caad10 record zonda
snaxez
by snaxez
cwdzoot wrote:
Tue Jan 29, 2019 7:14 pm
My frame will not allow me to use wider tires, current vittoria 25 tubulars are ok, but can`t go wider.
Js2
by Js2
EE brakes are decent enough if you're looking for the weight savings.
Having used both R9100 and EE brakes, I would give the nod to R9100. The brake feel and power is just a notch above the EE's.
Also EE requires a bit more TLC setting up and cleaning (gets gritty from time to time).
Currently on DM Dura Ace which is even better than the Regular R9100. Hope this helps
